Howdy! We have another patch update, improving camera support and fixing minor bugs. As always, a full change log is below.
Anything about this privacy issue? That’s pretty serious, as well. If I am going to use this software on any images for which I have any obligation to make sure that privacy, confidentiality, and intellectual property rights are properly observed, then I really need to know that this program isn’t sending these data anywhere without my explicit consent.
When doing sharpening, by default it chooses lens blur. If I manually change it to standard or strong, I get these little squares around the subject. I have subject detection set to none.
It also looks like the colors are being changed. I have adjust lighting and balance color set to disable.
Anyone else having this problem? These problems have been there for a little while.
I also posted in the 2.3.1 thread that for one set of photos, a kid is wearing a black winter hat. The color changes on part of the hat to grey in a square blocky design, similar to what you see around the fox in this photo.
No man, it is so frustrating that you still couldn’t fix the face-detecting issue. What is going on??? Now I must uninstall this version again and go back two versions for it to work. It works fine in v2.3.0 so why is there a problem with the next two versions? Don’t fix something that’s not broken!!!
please do fix the face detection problem as soon as you can but also the problem with the sliders hanging on sharpening etc as mentioned by others topaz tries to start proccessing as soon as you touch them instead of waiting a split second to see where the slider is positioned
this also started with 2.3.0
Just updated from 2.1.0 to current version, the programm crashes nearly intand after drop any image into it! no error message, the program just closes.
