Sharpen AI v2.0.0
When I use ARW (Sony Raw) files as Input, I get all black output images. Tested with JPG, TIFF, DNG. No difference between standard or mask mode.
Single Output (not batch), the images appeared in the selected directory.
Hello, Sharpen AI v2.0.2 Enregister sous filname.dng, le fichier de sortie a perdu toutes les mĂ©tadonnĂ©es du RAW d’origine, c’est ennuyeux pour le suivi des informations, pour le dĂ©veloppement automatique dans CameraRae et donc aussi dans LR.
Pouvez-vous, s.v.p., y remédier dans une prochaine version ?
Merci de m’avoir lu.
Yves
Hello, Sharpen AI v2.0.2 Save as ** filname.dng, ** the output file has lost all the metadata of the original RAW, it’s annoying for tracking information, for automatic development in CameraRae and therefore also in LR.
Can you please fix it in a future version?
Thanks for reading me.
Yves
@amy.mae : maybe most of the problems can be fixed by just check the installation process. At least for Windows users one of the main reasons for weird application behaviour seems to be the fact that installation does not apply some registry values for users with standard accounts (i.e. not admin users).
This is a problem of all Topaz applications that use the new installer and create registry entries in the [HKEY_CURRENT_USER\Software\Topaz Labs LLC] branch. In this registry branch the key DataPath is just missing.
Please see a detailed description of the problem and how to fix it here and (for Denoise AI) here.
I have this 2.0.2 installed on 3 Win 10 machines and do not experience this behavior with ARW files.
If you post the graphics info from Help > Graphics Info it will aid in assisting you.
@Linda Imgreene
Here is the graphics info:
Application & Version: Topaz Sharpen AI Version 2.0.2
Graphics Hardware: Intel(R) UHD Graphics 620
OpenGL Driver: 3.3.0 - Build 26.20.100.7263
CPU RAM: 16275 MB
Video RAM: 1500 MB
Preview Limit: 3466 Pixels
Black screen
copied graphics info
Graphics Hardware: Intel(R) HD Graphics 520
OpenGL Driver: 3.3.0 - Build 21.20.16.4821
CPU RAM: 12208 MB
Video RAM: 1500 MB
Graphics Hardware: Intel(R) HD Graphics 4600
Computer #2
OpenGL Driver: 3.3.0 - Build 20.19.15.5070
CPU RAM: 16136 MB
Video RAM: 1500 MB
Preview Limit: 3135 Pixels
You will need to use Intel OpenVINO under the advanced processing options as the HD Graphics 620 doesn’t have enough dedicated vRAM, it only has 115MB.
You will need to use Intel OpenVINO under the advanced processing options as the HD Graphics 520 doesn’t have enough dedicated vRAM, it only has 115MB.
Again, you will need to use Intel OpenVINO under the advanced processing options as the HD Graphics 4600 doesn’t have enough dedicated vRAM, it only has 115MB.
The Key is not missing in Windows 10, mine says “D:\ProgramData\Topaz Labs LLC\Topaz Sharpen AI” after the install which is correct.
It is best that the application is installed with Admin privileges and the registry is NOT altered.
Win10 Pro.
I clicked the link in your email. That downloads and installs v2 into c:\ProgramData
Strange location, but experience says not to mess with your choice of location on install, as things then tend to get screwed.
So, have the initial version installed in that directory.
Then ran the new v2.
Before anything else came up, it tells me an upgrade is available, and the whole install process gets re-started, but this time with the target directory as c@\program Files\Topaz Labs LLC
That then puts a vull install of 2.0.2 on my hard drive
So now I have THREE versions - all big - sitting on my SSD.
the option
enable Intel Openvino is already set to yes.
I did not enable the discrete GPU because setting this option slow down the system extremly.
When I use a dng as input format sharpen ai gives me a very small dng as output (256 * 191) with a filesize of 70 MB. Same with ORF (Olympus RAW)
Well, for my normal user account it was missing although I ran the setup as administrator (“Run as Administrator” in context menu of setup file). It was there for the admin account. So there must be a difference between your setup and mine.
Is your user a member of the administrator group ?
I am not a computer genius. Where might I find that to do this. Thank you
It doesn’t unless you change it. The default install directories are as follows:
  • Program Executables: Installed into your Program directory
    Program Resources: Into ProgramData
You have then installed them into separate directories.
Advanced Preferences in File-> Preferences
excellent Thank you
Unfortunately, that didn’t help. Any other suggestions would be appreciated.
Thank you
Can you tell me the size, in Pixel dimensions, of the image you are processing.
Do you have an alternative GPU on either of your PCs?
