Starlight Mini - Large Grid / Large Blocks Problem on Dark / Contrasty Footage
  1. In this Starlight Mini 4x Upscaled footage, I’m seeing large blocks moving around in a kind of grid. I’m including the standard definition source footage for you to test, the 4x upscale showing the problem, and an enhanced version of the 4x upscale to better highlight the problem.
Source Footage
Starlight Mini 4x Upscale - Original Output with Problems
Starlight Mini 4x Upscale - Problems Enhanced
  1. Processor 11th Gen Intel(R) Core™ i7-11700F @ 2.50GHz 2.50 GHz
    Installed RAM 16.0 GB (15.9 GB usable)
    Graphics Card NVIDIA GeForce RTX 3090 (24 GB)
    System Type 64-bit operating system, x64-based processor
  2. Your log files (Help > Logging > Get Logs for Support)
    logsForSupport.zip (10.4 MB)
Screenshots from the Enhanced Version to better showcase the problem:
typical issue of starlight mini
Are you able to share the source and exported videos for testing?
  1. input video
  2. exported video
Submit File to Dropbox
Source and exported videos, and the note with file names, have been submitted. Thank you so much for investigating this.
7.1 is released…this issue remain unsolved or not?
Nope.
Still present on Starlight Mini in Topaz Video AI Beta 7.2.0.0.b
Based on this comment: Topaz Video AI Beta 7.2.0.0.b - #92 by michael.carter-7687 sounds like it’s also present in SL Sharp.
So its a basic issue that stay forever…
Sorry it’s been a while, can you let me know the file names?
VTS_01_2.MPG
This is the direct original MPEG-2 footage I worked from
VTS_01_2 Deinterlaced 50fps - File Used in Topaz.avi
This is the footage I loaded into Topaz and processed with Starlight Mini. It was deinterlaced with QTGMC into 50fps. It uses the lossless Lagarith codec.
Full_starlight_mini.mov
This is the resulting footage processed by Starlight Mini.
Problem Areas Enhanced.avi
I adjusted the levels and sharpness to bring out the problem areas I am seeing. Although now “exaggerated”, the blocks are still noticeable in “Full_starlight_mini.mov”.
