Akila
(Akila)
March 22, 2024, 7:05pm
Not directly related to the Program, but…
there is an issue uploading images into the forum post as you guys added an additional CDN that it’s Domain name (community-cdn.topazlabs.com ) is not included in your SAN (Subject Alternate Name) SSL/TLS certificate of this forum.
Either issue a new SSL certificate with community-cdn.topazlabs.com as part of the Forum SSL certificate SAN or uploaded pictures to the CDN should be linked in the Post in HTTP (not HTTPS).
here are some post examples with the issue…
I’m processing over 190 small video files in batches of 10 or 12, but when I start the batch processing, only the first file is processed. The program asks me to name the saved file, and that’s the only file processed. The Export button has is identified with the correct number of files to process, i.e., for 12 files, the export button reads “Export (12)”. I’ve batch processed files before and have never encountered this problem. I haven’t yet batch processed with any version 4 or over.
My syst…
Hi,
I am getting errors while running ffmpeg command in command prompt (screenshot attached).
Steps to reproduce -
Open Command prompt from GUI.
It open terminal with path /Applications/Topaz Video AI.app/Contents/MacOS.
Run command -
./ffmpeg -hide_banner -nostdin -y -strict 2 -hwaccel auto -i "/Users/kunal/Downloads/new_garment_overlay_vid.mp4" -c:v "hevc_videotoolbox" "-profile:v" "main" "-pix_fmt" "yuv420p" "-allow_sw" "1" -vf "tvai_up=model=amq-13:scale=1" "/Users/kunal/Downloads/…
Thanks @Akila for bringing this up, the team has been made aware and see that something is broken. They will get on to fixing it shortly.
Akila
(Akila)
March 23, 2024, 9:43pm
4
The method I use that works well is, Copy the Picture to clipboard (CTRL + Print Screen), then paste (CTRL + V) into the post. that works very well.
