Problem observed:
When I export a video with a mark in and mark out, the resulting file’s duration is the (original file duration - mark in) and not (mark out - mark in). This seems the same as another bug, which is inexplicably both auto-closed and marked as “investigating”. I’d link directly, but it doesn’t let me link to the same forum?
Repro:
- Open a video, preferably a long (e.g. 1+ hours) one to best illustrate the issue, but any should do. I’m going to use the 720p Sintel video from the Blender open movie project for this example. I’d provide a direct link, but apparently the forum software doesn’t like that.
- Mark in at 3 minutes into the video (Sintel jumping onto the roof)
- Mark out at 3:30 into the video (Sintel holding the baby dragon)
- Click “Export As”, all default settings, no models or alterations needed
- Notice that the exported file starts in the mark-in location, but somehow has the same length as the original file minus 3 minutes (11 minutes, 50 seconds). Seeking after the 30 second mark does not work, so the correct amount of video was encoded.
Screenshot of incorrect duration:
Since I marked in at 3 minutes and out at 3:30, the length should be 30 seconds.
I can upload the video if you’d like. I imagine that setting a low bitrate and shortening it up will make it small enough to upload easily.
System Profile:
There doesn’t seem to be a great way to automatically do this. Here’s some info:
Processor 13th Gen Intel(R) Core™ i9-13900K, 3000 Mhz, 24 Core(s), 32 Logical Processor(s)
Installed Physical Memory (RAM) 32.0 GB
Adapter Description NVIDIA GeForce RTX 4090
Video AI log (zipped):
2024-11-07-22-35-17-Main.zip (11.8 KB)
