Motion deblur gives the kind of quality i want from my 2009 camcoder but Zooming in everything looks very crusty!
Read my tip above, it might help.
I didnāt understand what appolo or appolo soft is supposed to do. Is he a bit like themis?
Apollo is for creating a higher frame rate or slow motion. Themis is for reducing motion blur.
Okay, thanks, but if we use Appolo with the same frame rate, there are no changes on the image? And will we be able to get a good quality if we double the frequency (from 50 fps to 100 fps) with Proteus in addition and we redefine 50 fps in the editing software?
The simple answers are no and yes, keeping in mind that quality perception can be subjective.
Zooming In percentage is not correct on a high-DPI display, the preview at 100% scale is not Dot by dot
Would you add a feature so that multiple processes can be queued up to run one at a time instead of all ran at the same time? If there already exists this feature, I canāt seem to find it.
If Iām upscaling to 4k and converting to 60 frames per second, do I need to separate the process? And what to do first, 4k or 60 frames
If 60 Hz is the max your TV can do then yes 60 fps will probably look smoother as it canāt output 120 fps (maybe it will skip every other frame).
If your GPU/desktop is set to run at 60Hz and your monitor has a max of 60Hz then then 60Hz should look the smoothest on that system (since it wonāt skip frames). Or the desktop/monitor might actually be running more like 59.94Hz so it might be a bit better to output at 59.94 fps. Same for TVs. if you want the smoothest motion (if it canāt handle 100/120 Hz).
NVIDIA GeForce RTX 3060 (12 ŠŠ±)
It depends on your monitor too.
Click on ānvidia control panelā and go to display->change resolution and see what your resolution and refresh rate is and see what refresh rates are available in the list and what it recommends (eg. in mine it only offers 60Hz in that list because thatās what my monitor outputs. I also have a higher refresh monitor but itās not being used with this pc). You can check the specs of your monitor too re: refresh rate. If the monitor could do >60Hz it might only do that with a certain connection. So check the refresh rate of the monitor - it should say in the specs/product info.
You could also check your TV specs - if that can play through a USB stick at 120 Hz (120Hz refresh rate) you could render a version for the TV at that refresh rate and it may look smoother.
I now have all the monitors 60kHz, but in the future, hopefully there will be 120! If I zoom in from HD to 4k and convert to 120fps, do I need to separate these processes into two passes? And what to do in the first place, 4k or 120 frames? Or just choose Apollo+Artemis
By default it allows you to select a model for frame rate increasing and a model for the enhancement (eg. upscaling). So you could just do that (so itās basically chaining the process there - probably doing 2 renders internally (or more if you select the other options like stabilization/deblur) with a temporary file). I donāt know if there might be quality improvements doing it in another way (eg. 2 renders that you do yourself) eg. where you have the option changing the order (eg. upscale then the frame rate increase).
As a feature request - maybe there could be an option/model for flicker reduction in video (eg. some CGI can output flickering - eg. if there are thin lines in it), where you could control the amount of flicker reduction.
I donāt really understand what you wrote. I take 4k video and add 120 fps to it with Apollo because Chronosās incredibly distorts every video where thereās camera movement. Also, I take DVDs, or Blu-ray, and convert them to 4K120fps.
I wanted to hear advice from you in terms of the interface of the TopazAI program.
Is there a difference in the quality of the final video if I convert straight to 4K120fps at a time. Do I need to process the video before 120fps first, and then, the second time, up to 4k. Or vice versa?
Try this: open Preferences and set Max Processes to 1.
There shouldnāt be a quality improvement converting to 120 fps first, then rendering to 4K as thatās probably what itās doing anyway with temporary files when you select to do both things in one go (when you select to increase the frame rate+increase the resolution). Thatās assuming the renders for each one are done in a high enough bitrate and high quality codec. But doing things individually would allow you more control and to change the order of things.
But I havenāt compared the quality of each way of doing it so I canāt tell you for sure. Maybe someone else has done tests for those things that can give you an accurate answer. Or you could try both ways of doing it to see which you think is best.
Thanks! Iāll experiment.
And what do you think. To convert HD video to 4k, would the Artemis Highte model be better, or Theia? DVD on 4K?
