Topaz Video AI Beta 6.0.1.0.b
I did check the footage in avspmod ( kinda like virtualdub )
And add this bug to that list:
One full year later this is still there - even though it was acknowledged and said to be solved ā€žin a comin updateā€œ :grimacing:
something changed causing temp files to do into a folder under Documents, which then syncs to OneDrive… bit annoying default behavior change.
I have seen this behavior on other software, one I can remember is Avidemux. This happened more than a year ago after a macOS update. My guess is something was changed by Apple and developers need to update their SW. Not an excuse for Topaz not fixing it though :slight_smile:
