The bug / behavior you have encountered
If you open a save dialog in TVAI (e.g. Export as) the cursor keys don’t actually move the cursor in the filename text entry field but instead move the video one frame forward/backward.
Your system profile
Mac Studio M2 Ultra, MacOS Sonoma
Your log files (Help > Logging > Get Logs for Support)
No logs needed
Any screenshots as necessary
here is a screen recording of the erroneous behavior: TVAI-cursor issue.mp4.zip (1.2 MB)
When editing the file name of an export before committing to saving the arrows keys do not work. It is really helpful to use the arrow keys to move the cursor around the text.
Instead when you use the arrow key left and right it moves the frames of the video in the background.
Every other application has it so that when you are in save mode like this you can use the arrow keys to move the cursor.
Otherwise phenomenal product this is the only bug I have found.
Yes I have experienced this with every release I can recall. Would be a significant improvement as I edit the suffix of every export with my own naming conventions and it is significantly faster to use the keyboard vs the mouse.
