Topaz Video AI Beta 3.1.0.2.b
@suraj @nipun.nath @eric @amy.mae @gregory.maddra @emmanuel.nwosu @yazi.saradest
Devs, thank you for all the work and effort you are putting into the TVAI project, but please try to consider adding these enhancements (I have created a dedicated post):
Ps. I ask those who are interested to vote on my request so that it can still be highlighted (it would also be nice to be able to divide the requests into two: on one side all the requests that are now “closed” and resolved, while on the other side all the pending requests that have yet to be either approved or added to the program)
For anime I use ESRGAN model DigitalFrames 2.1 or 2.5. Which is not good at removing noise so sometimes I combine that with a pass of CUGAN. DigitalFrames is sadly not available anymore publicly from its creator. DM me if you want a download link.
Apollo soft model gets stuck after ‘‘model loaded’’. Using 5950x and 3070ti
Fyi Apollo sharp works…slowly but works
2023-01-13-21-28-45-Main.tzlog (36.1 KB)
Hello Suraj.
Metaphysical notes to the new version v.3.1.0.2b
I let it process for a few hours and I find that the process is finished, the graph and the fans do not stop…the door does not close.
Error detection system from progressive to interlaced does not detect correctly. Check the same sequence in v3.0.12 being correct in this latest version.
Great advances in the rest of the new models.
Themis requires manual adjustments as a Beta tester for conclusions and technical evaluation.
The path is made by walking…
@suraj @nipun.nath
This version has a touchy (hanging GUI) spot.
It most commonly happens at the moment a preview rendering completes.. (Auto replay is turned on.) - The ‘auto’ replay does not begin. Clicking anywhere on the GUI grays everything out and a “Not Responding - click/wait message box shows.” Selecting “wait” does nothing.
As such, it is damn near impossible to get settings made before starting an Export.
This is the log:
logsForSupport.tar.zip (198.0 KB)
Let it sit for 4-5 minutes it will start, keep an eye on your cpu usage. IM finding the apollo soft model and the new de-blur model are only running on the CPU for some reason. Hence the slow loading and processing times.
Im finding the Beta released today 3.1.0.2.b, the motion deblur model takes AGES to load and process. im on rtx 3080 10gb, anyone else see this problem? All the other models work fine and I do see a noticeable speed/processing time improvement across the board. My processor in the preferences is set to the RTX 3080 only.
Edit: just noticed my gpu isnt being used at all. But my CPU is at 70%. What would cause this? its just this model thats doing it
Edit #2: the Apollo soft model is also CPU bound only.
Edit #3, i deleted the model folder and redownloaded them and now apollo soft and sharpen are running on GPU. but the motion deblur is still CPU bound only.
Im on latest nvidia gaming drivers (makes no difference i’ve found for VEAI if im using studio or not).
Hi nipun.nath,
I succesfully installed this 3.1.0.2.b version and everything looks good.
No crash.
Rendering speed on my old nVidia 980 M is the best I got !
Great speed and picture quality good too.
Need to be more tested to experience crash or visual artefacts.
I shall post again later.
But this version is really good.
Kind regards.
Vincent.
P.S. : still have the issue of no licence, so I use the trial mode. Could be interesting to have a temporay licence just for testing.
I did leave it running for a long time before. But I’ve started another test and will leave it on and time it to see if it starts sometime. Also regarding your next comment about Apollo being only cpu bound. maybe Apollo is a ‘‘cpu only’’ model for now and might not have cuda support yet. Dev might confirm this at some point. So it’s slow for now, but I like the quality.
Hi maaru,
How you get the Apollo option ?
I tested and get only the standard model engines !
Thanks a lot.
Sorry I got it while changing the interpolation mode !
Come from 50 fps to 25 fps and got Apollo !!!
My mistake…
In this beta version, under frame interpolation models.
Edit: I need to read the full comment before posting. I see you found it :slight_smile: Sorry
I updated my next comment, i deleted the models and redownloaed and both the apollo models are gpu bound now. But the deblur im still investigating.
I see, i’ll need to try this. Thanks
Hi Maaru,
Thanks.
Do you have this issue:
  1. import a video to FPS interpolate ;
  2. go to a specific point on the timeline ;
  3. perform a preview (it downloads the AI model) ;
  4. go to another specific point on the timeline ;
  5. perform another preview without changing any settings (just the position of the timeline).
Result :
On my system, it downloads again the AI model already downloaded at step 3 !
LOL !!!
Speed increase on the Proteus is significant, great job team !!!
Just started testing today, because previous version had grain issues - those are fixed now, i confirm.
However, deblur is veeeery slow for now, and results not as expected, but lot of testing to be done…
Hi srdan.jelic,
Yes I also noticed speed increase and I own an old laptop with a nVidia 980 M.
And it is two times faster at least !
They have done a great job…
Nope, I don’t have this issue, I just tested previews using Proteus, Gaia and Apollo. It only downloads the model once for me.
Just to confirm on my test clip I’ve used for ages.
3.0.12 - 4.2fps = 01:52
3.1.0.2.b - 7.8fps = 00:59
Quality is the same on both clips
Proteus, manual, estimate on first frame.
Getting there :+1:
Yes, deleting the models folder worked. Apollo is using the GPU now. Thanks for the tip. Speed went up from 0.3 fps to 2.3 fps. Nice. Btw Apollo soft still does not work even after the model redownload and I left it running for 20 mins before I quit, so there’s probably a bug with that and/or my pc hardware combination.
Great to hear. Sorry the other one didnt work, mine did, not sure why. I really wish the deblur would work though I want to try it out.
