Topaz Video AI 4.0 error with using multiple GPUs, works fine when 1 GPU is selected
    When File>Preference>Processing>All GPUs are selected, processing with any models will crash with error! However, when only one GPU is selected to be used, it went fine. This probably happened before v4.0, I’ve reported this since v3.5.x but I didn’t realize the cause was by selecting uses “All GPUs”
  2. Your system profile
    2x RTX3090
    intel 19-13900K
    64GB DDR5
    logsForSupport.zip (665.4 KB)
This is now fixed in 4.0.1!
awesome! tested and works now!
