Topaz Photo AI v3.4.3
yeah it doesn’t work
Well, they DO work here on two different locations (home and work). So it is likely due to some settings with your internet?
Do you use a firewall, VPN or something like that? Some restrictions by your provider?
I did already and and used 3 different networks still it has the same issue
Hi.
You didn’t answer jo.vo question do you have a VPN enabled if so then you need to disable it then try downloading and installing the latest version
Here’s the link for both Windows and Mac versions
Windows
https://downloads.topazlabs.com/deploy/TopazPhotoAI/3.4.3/TopazPhotoAI-3.4.3.msi
Mac
https://downloads.topazlabs.com/deploy/TopazPhotoAI/3.4.3/TopazPhotoAI-3.4.3.pkg
If this doesn’t work then please contact Topaz Support
Topazlabs Support
support@topazlabs.com
Hope this helps
@spike_mike-93427 - for the Batch Processing issue, this is now resolved in Photo AI v3.4.4 -
