Topaz Photo AI v3.4.3
Hello! Today we have a patch release for Photo AI which fixes a number of workflow issues in the application.
Included in this patch are bug fixes for some of the new features not appearing for the correct sets of users as a part of our gradual rollout plan, as well as fixes for several UI/UX issues which could cause problems such as buttons and filters not working as expected.
This patch is a regularly scheduled update in addition to the important fixes released in version 3.4.1 and 3.4.2, so if you’re experiencing any issues with model downloading or grid artifacts, please check to see if you’re on 3.4.0 or 3.4.1 and upgrade to the latest version. You can read more about the recent patch updates here:
We will continue to update Photo AI with additional bug fixes as needed to improve performance, stability, and the overall user experience leading up to the next major release.
You can find the installer links and the full changelog below for this version of Photo AI.
v3.4.3
Released December 30th, 2024
Windows: Download
Mac: Download
Changelog
  • Make zoom to 100% work as intended, not zoom to fit
  • Added support for pro tips in future releases
  • Fixed a workflow issue when switching super focus tabs
  • Fixed issues with sample images and other feature flags working properly
  • Fixed upscale still not being last in the stack sometimes
  • Fixed an issue where open file was clickable when it shouldn’t have been
  • Fixed an issue where the next/prev button was always disabled
  • Fixed an issue with the space bar adding suggestions
  • Fixed token expiration warning always showing when offline
  • Fixed an issue with analytics logging
  • Fixed default slider values in denoise and upscale being 1
  • Fixed multiple issues. caused by applying AP (with upscale) to all
  • Fixed issues with panning/zooming/brushing while removing objects
  • Fixed an issue where removing all enhancements broke the RAW filter
  • Disabled shortcuts when the support dialog is opened
  • Multiple small UI and UX fixes
  • Added DCP for Sony Model ID for ILCE-1M2 (full support coming soon)
  • Automatic Lensfun Update
Cheers,
Dakota Wixom
Product Manager
Topaz Labs
Thanks for the details but the statement…
“We will continue to update Photo AI with additional bug fixes as needed to improve performance, stability, and the overall user experience leading up to the next major release”
…implies that the software app will truly never be fully operational.
Still the same multiple “Preserve” suggestions when there is no text, then crashing when you select one of them…
Hello, the update is failing here.
Error message saying basically that the Windows Installer version is not compatible.
I’m using Windows 11 23h2 22631.4602
Try uninstalling and reinstalling the program with the latest version. But make a copy of the templates folder to prevent it from re-downloading everything. This could take a long time.
It’s possible that something is broken in your Windows. A service or files may be corrupted or even missing. Do you have the same problem with other msi installers?
All current software is like that. e.g Photoshop and Lightroom are regularly updated to remove bugs, add features etc etc, as is the OS you are running - Windows, macOS…
It doesn’t mean it is not fully operational but just being updated - which is a good thing.
Same here…
@Imo @andymagee-52287 Sorry about that, the windows build wasn’t set to show up as an in-app update. It should show up next time you open the app now.
Thanks Paul - we’re tracking down this issue. Stay tuned for a future update.
No problem with M2 Mac in-app update or performance so far.
Screenshot 2024-12-31 at 10.05.47 AM
Screenshot 2024-12-31 at 10.08.41 AM
How to find tiling patterns in TPAI:
  1. Open RAW image of a night starry sky
  2. Apply “Adjust lighting”
  3. Observe the tiling pattern from Raw Denoise:
  4. Add Sharpen All. Observe additional tiling pattern:
  1. Add Upscale. Observe additional tiling pattern:
Can you send us your NEF file (here to our Dropbox) and logs (from in-app Help menu > Open logs folder) to support@topazlabs.com? I will have a look at them and test it on our side to sort this out!
I uploaded NEF and log files to dropbox:
I noted in other threads that I see this happening in the Texas Theatre sample image (jpg) as well, among other images of mine (jpg, arw) and other users.
So after getting an email about the holiday discounts coming to an end and being locked into the subscription without any means whatsoever to find out what another year would cost me if not on subscription I decided to cancel it today to try to find out (it used to be possible to “stack” one year extension on another).
That didn’t work - instead I ended up with this:
I’m sorry, but this thing with how Topaz Labs handle the subscriptions is messed up on so many levels and in my opinion extremely poor business practice.
Rest assured that I will cancel my GAI subscription as well and simply just roll the dice with regards to future updates.
So long, and thanks for the fish?
The 7840HS has the 780M integrated GPU plus the Ryzen AI NPU. It is one of the most powerful integrated GPUs out there, but not up to the level of many of the discrete GPUs. I have a Win11 laptop I sometimes use that has the 7840U + 780M + Ryzen AI NPU, 16gb, 1tb. The 7840HS and 7840U are almost identical except the 7840HS has a very slightly higher clock speed (and more energy usage).
My 7840U runs Photo AI pretty well and not far behind my M2 Pro 12/19/16 16" Macbook Pro 32gb/1tb. But if I try to use Super Focus on the 7840U I get this error message. Is this the same error you get?
pai
My Win11 laptop meets the system requirements, I think:
docs.topazlabs.com/photo-ai/system-requirements
But Super Focus clearly needs a lot more than the other models. I think Topaz needs to update the system requirements and maybe add a remark about Super Focus needing more than the other models.
@ with1an To know why you are getting the Error running model, can you send me your Logs and System Profile to support@topazlabs.com? It can be caused by multiple things and having your logs and System Profile can show us what is happening!
Logs: from the app, go to the HELP menu then Open logs folder. Zip all the files and attach them to the email to support@topazlabs.com
System Profile: How To Obtain Your System Profile (Windows) - can attach it to the same email!
@david.horita and @michaelezra - great thanks. Will check these and get back to you here!
Reminder to:
Download your free Plugs n’ Pixels Gigatextures for use in your digital art projects (Dropbox, 786 MB, zipped).
Catch the last few hours of the Topaz Holiday Sale (30-50% off).
