Hello!
We are excited to announce another update with Photo AI v3.4.0 releasing today!
This post has also been updated to include notes from the 3.4.1 and 3.4.2 patch.
With this version of Photo AI, the Preserve Text enhancement will now automatically run on areas of your image where text has been detected. You can also regenerate results using Super Focus, which is faster than ever before on all operating systems. And cropping is now easier to use, receiving a major redesign which you’ll love.
We’ve also made some major updates to help new users get the most out of Photo AI, with tutorial videos and sample images, as well as a way to contact our amazing support team from directly within the app.
This update to Photo AI includes:
- Intelligent Text Detection for Preserve Text
- Major Improvement to the Crop Tool
- Face Recovery for Side Faces + Mac OS 12
- Regeneration for Super Focus
- Camera profiles for Olympus and Panasonic RAW
- In-App Support Outreach
And some users may also notice:
- Welcome Screen with Tutorial Videos
- Tutorials inside Suggestions
- Sample Images
Please note that the tutorial videos, sample images, and welcome screen changes will be progressively rolled out to all users based on feedback. Don’t worry if you don’t see it right away - you’ll receive access over time without any update needed.
And if you want to watch the tutorials right away - here’s a direct link to the Photo AI Tutorial Video Playlist
We have a lot to cover with this post, so keep reading to learn more. For any issues please reach out to help@topazlabs.com for support.
You can download the latest version of Photo AI using the links below:
v3.4.2
Released Dec 24th, 2024
Windows: Download
Mac: Download
Please note that we have updated this release to include a couple of important fixes. The links above have been updated to reflect this. Make sure you are working off of the latest version of Photo AI.
New Welcome Screen with Tutorial Videos
We are revamping the application start experience to help you get the most out of Photo AI with informative, easy to understand tutorials for both new and experienced users.
These videos share tips, tricks, and best practices for using the enhancements in Photo AI.
Here are the direct links to the tutorials. Please watch and let us know any feedback you have!
- Intro to Photo AI
- Sharpen like a Pro
- Denoise like a Pro
- Recover faces like a Pro
- Upscale like a Pro
- Remove like a Pro
- Super focus like a Pro
And here’s the entire Photo AI Tutorial Video Playlist
We’ll be adding more tutorials over time as well, so please let us know in the comments if there’s more that you’d like to see!
Please note that you may not see these tutorials in the app right away - as we are gradually rolling out this feature to users over time based on feedback. For now - use the links above if you don’t see them in the app!
Sample Images and Tutorials in Suggestions
Behind the updated welcome modal are new sample images for you to play with. These easy to access images are a canvas for everyone to experiment with the enhancements in Photo AI.
Each image also comes with a tutorial video that appears in the suggestions. The images and videos were created together so anyone who uses Photo AI can quickly become proficient with each tool.
Again, please note that you may not see these sample images right away - as we are gradually rolling out this feature to users over time based on feedback.
Intelligent Text Detection and Preservation
That’s right, Photo AI will now automatically detect text within an image, generate a custom text mask, and suggest the Preserve Text enhancement when your image has a large amount of text detected.
This will save you tons of time - you no longer need to mask out all the text in an image by hand to get the best results!
You can mouse over Preserve text in suggestions to show the detected text mask in the image. Adding Preserve text will auto-select Text every time, giving you a starting point for the enhancement. To make further changes, go to the Edit selection tab and use brushes to tweak the selection.
Not completely happy with your first Super Focus result? Now you have the ability to re-generate the “seed” of a Super Focus result if changing parameters does not yield the desired result.
A “seed” represents a unique starting point that guides our AI processing. While using the same input image, different seeds produce varying results - letting you explore multiple output versions until you find the best result for your photo.
To access the seed regeneration, run Super Focus. After the image has completed processing, enter the completed Super Focus edit and click the Regenerate button.
Important note: Once you regenerate an image, you won’t be able to return to the previous output, so make sure to save any versions you’d like to keep!
We believe in providing exceptional support, and now it’s easier than ever to reach our dedicated team.
At the top of the application is the new Get Help button where you can quickly create a support ticket. Describe your issue and easily attach your logs, problem image, or any additional screenshots. Submit to send it to our support email.
Our support team is always ready to help with any questions or feedback you may have!
Updated Crop Tool
Crop gets some more love with this update! You can now seamlessly switch between aspect ratio and size modes depending on your cropping needs. This makes it easier to crop an image down to an exact pixel size, or aspect ratio if you prefer.
In Size mode, specify exact pixel dimensions to use with some quick select options for the most common crop sizes. In Aspect Ratio mode, select the relative aspect ratio instead of pixel-wise dimensions.
We’ve also updated Crop to be more stable and performant in this release.
Updated Face Recovery for Side Faces and MacOS 12
Everyone loves Face Recovery in Photo AI, and we have made yet another update to the model which will dramatically improve results for faces which are shot in a side profile.
This update also allows the model to run on macOS 12 devices, which was not possible before.
This is part of a larger initiative to improve the quality of face recovery in even more scenarios such as with diverse skin tones, body jewelry, and more.
Check out some of these amazing examples:
Left: Original, Middle: Before the update, Right: After the update
Camera profile support for Olympus and Panasonic RAW files
Last but not least - we are excited to expand improvements to more camera manufacturers!
When a Olympus or Panasonic RAW is imported, Photo AI reads the metadata for camera manufacturer, camera model, and camera profile. The header now includes the camera profile detected and applied to the RAW file.
Olympus before (top) and after (bottom)
Panasonic before (top) and after (bottom)
Even More to Come
With your help, Photo AI is getting better every single day behind the scenes.
There’s so much more more coming to Photo AI, and we can’t wait to share with you everything else that we have been working on - including new AI models and so much more next year.
We’ll share more about future plans for Photo AI in an upcoming Roadmap post.
We’ve also fixed a number of important issues with this release of Photo AI, as well as the previous patch releases. You can check out the full changelog below.
Cheers,
Dakota Wixom
Product Manager
Topaz Labs
Changelog
- Added Intelligent Text Detection for Preserve Text
- Added Major Improvement to the Crop Tool
- Added Face Recovery for Side Faces + Mac OS 12
- Added Regeneration for Super Focus
- Added Camera profiles for Olympus and Panasonic RAW
- Added In-App Support Outreach
- Added Welcome Screen with Tutorial Videos
- Added Tutorials inside Suggestions
- Added Sample Images
- Added -crop suffix to file exports with crop
- Updated model selector for Upscale
- Multiple fixes for product metrics
- Fix applying presets sometimes moving some filters below upscale
- Fix crash on startup when offline
- Fix crash when adding multiple sharpen enhancements
- Fix subject masks always saying “auto”
- Fix reactivation window not appearing on windows
- Fix OpenSSL issue with plugin flow
- Automatic Lensfun Update
- Exiftool update
3.4.1 Update Notes:
- Fixed grid artifacts with the High Fidelity v2 upscaling model
- Fixed issue with crashes during import on some images
- Fixed some incorrect spacing and colors in Light Mode
- Updated app icon
3.4.2 Update Notes:
- Fixed Mac model download in installer
Known Issues
- You may need to log out and back in to see the Get help button
