I went through the steps to install, and it did not actually install.
Now whenever I click the Update Available button, then hit Install Update, the program quits.
It’s one thing after another with every update since the debacle of 2.1.2
I still can’t process more than 1 photo at a time without the program crashing.
Sometimes, it only takes a single file to crash.
I went from very pleased to extremely disappointed with this program
In case anyone is curious, my computer is:
MSI gaming laptop with intel i5-9300H CPU @2.40 ghz, 8 GB ram
GeForce GTX 1650 w Max-Q, driver v 512.15
I have yet to have anyone provide any suggestions on my problems
(Windows 11) Version 2.2.2 says that there is an update available (presumably this one). I click on “Update Available” and immediately the button changes to “Install”. I click the button, Topaz Photo AI closes, then nothing happens. I check Task Manager and Topaz isn’t running and neither is Windows Installer
See AiDon’s post above yours. There have been numerous posts about the in-app update not working. it’s definitely best to use the installer from the first post.
Latest update does not install - click update, no problem. Then click install and window closes and notbing happens. Tried numerous times. PC Windows machine.
I downloaded the Windows executable of the new version from this page, and once started it asked me if I wanted to repair the software or uninstall it.
at which point I screwed the dinistallation, rebooted and re-installed the new version with the full program package: no problem!
Support and I have been trying different things all to no avail. So for grins I tried loading up 2.2.2 and all went according to Hoyle. So I’m betting the the problem lies with the installer code.
Yes, very strange! As far as I’m aware I should have everything up to date including graphics drivers. Every other graphics program installs including Gigapixel AI after following your suggestion a few days back.
Standard v1 and v2 should be same time cost at least. Can you help send me a log file for a session running both v2 and v1 standard model for us debugging?
