I noticed that RT models are smaller too.
My W6800 does need 4 GB vram vor TVAI were the RTX 5000 does neeed only 2 GB.
So even if you have 8gb gpu, it will still use cpu?
If it needs more gpu vRam then it should not be bypassing the gpu.
Yes, Nvidia GPUs usually consume less VRAM than AMD GPUs, including during gaming, because Nvidia GPUs have better data compression techniques that help reduce VRAM usage.
I remember watching a YouTube video where a YouTuber tested several games at 4k maximum detail and texture settings. With a 16GB AMD GPU, the frame rate dropped and the game froze due to a lack of VRAM. However, with a 16GB Nvidia GPU, the game played smoothly without any problems.
Furthermore, they tested the same scene with a 24GB AMD GPU and found that it consumed around 18-20GB of VRAM, while the 24GB Nvidia GPU only consumed 16GB of VRAM.
(I canât remember the exact number in the video, so the number may not precise)
Just to clarify, I am not saying Nvidia is better than AMD. I believe they simply use different approaches. Nvidia GPUs may require extra hardware or chip space for data compression, which enables them to save some money by having less VRAM.
On the other hand, AMD GPUs may save some money on data compression in exchange for allocating more VRAM to their GPUs, making the specs more appealing to customers. This is because most consumers tend to compare numbers without fully understanding the technology behind them.
Tanks for the info, i didnât know about this. ![]()
So what you are saying is, you donât need as many gb of vRam on Nvidia GPUs. So if AMD needs 8gb, then Nvidvia only needs 4 or 6gb to run, as well. Not all GPUs are the same, compare the RTX 4060 with the RTX 3050 both with 8gb of vRam and the 4060 is much faster. Not sure how relevant gaming tests are when using for photo editing. Should users be downloading studio drivers for their GPUs, instead of gaming?
I have read similar things about AMD, thats why Iâm getting Nvidia.
If youâre into TPAI (which you said you arenât) then a Mac mini with Apple Silicon would be the best bang for buck atm.
Comparing TPAI on my MacBook Pro with the M1 Pro it runs circles around the PC with I7 13700 and GTX 4600.
(So with TPAI we have a situation exactly the opposite to TVAI where currently Macs really underperform ).
EDIT: Shouldâve read RTX4060, not GTX 4600
A rough and dirty try resulted in something only remotely useable - maybe for small mobile phone screens, but not for viewing on a bigger monitor and for sure not for printing.
And even this needed MANY steps (30+) and would need heavy afterwork with the copy stamp to get some skin texture back plus the borders arenât clean/sharp and it trounced the models shoulder. So Iâm not sure if you wouldnât be faster using just the copy stamp from the start.
If you have a drawing tablet with a stylus it might be more convenient and more exact than having to do this with a mouse but still this kinda defeats the purpose of AI (getting decent results with little effort).
So (Topazâ) AI currently isnât really up to that task I guess.
For same VRAM, Nvidia GPU have the advantage.
But if you ask smaller VRAM Nvidia vs larger VRAM AMD, I donât think there is a simple answer for this question. The effectiveness of data compression can vary significantly depends on application
It all boils down to price/performance. How you get there is irrelevant.
So NVidia has better compression but then at least here you often get an AMD GPU with more RAM for the same price or less than the Nvidia cardâŠ
I also played with this image yesterday, it is a bit difficult to deal with in TPAI. It require lots of trial & error and require regenerating multiple time.
On the other hand, I tried with Lama cleaner, it remove the tatto within seconds. Here is the result
Before and after
But in Lama Cleaner the uniform grey skin color of the arm is off / looks unnatural. And while not that over smoothed as the TPAI result the âtextureâ really isnât a texture but just noise if you look closer :-/
Maybe Lama Cleaner and then some afterwork with the copy stamp would be the fastest in this case.
I donât want a Mac. Macs are expensive in the UK and upgrades are also. All my software is Windows based.
Minis are difficult to upgrade because of the limited size of the case.
Yes AMD prices tend to be lower because of lack of demand. Although looking at my choice from my supplier, prices donât seem that different. RTX 4060 is around ÂŁ300, what AMD gpu matches that?
They are not difficult to upgrade, itâs just impossible ![]()
Still, bang for buck in TPAI is good. And no, theyâre not really much different in price in the UK compared to Germany.
GTX 4600.Is that correct, I canât find it?
I will give Pai more time, only been using it for 2 weeks. I really only use Sharpen, DeNoise and Gigapixel. If I buy the DxO Raw converter then I wonât need to use DeNoise much.
I meant RTX 4060 - which really isnât the best/fastest card, btw. Itâs limited by several bad design decisions.
But the PC was built for a totally different use case and TPAI / TVAI running there just for interest. And for the intended use the RTX 4060 was a good choice price/performance wise. A 3060 wouldâve also done but that wasnât really available at at the time
For photo / video work I have the MacBook Pro and the Mac Studio.
Do you mean RTX 4060? So which gpu do you think is better?
You can upgrade Macs but the prices are a bit crazy from Apple, for example increase RAM from 8gb to 16gb is ÂŁ200 but on Win pc, it is about ÂŁ13. Same for HDs, ÂŁ400 for ssd, from 250gb to 1TB.
The RTX 4060 performance is roughly equivalent to the Radeon RX 6700 10GB.
My Go To Source For Selecting A GPU Upgrade
I never invest in the premium you have to pay for the latest top of the line GPUs. If you go down a tier or two the price/performance value is typically much better. Sadly, bitcoin mining has completely distorted the whole pricing logic of this market.
Do keep in mind that as time goes by any particularly popular model will slowly reduce in price, and then eventually skyrockets again as it goes out of production and becomes hard to find, but still in demand.
I run my 4 year old RTX 2070 Super on a 1440k ultrawide monitor, and at that resolution itâs still equivalent to the much newer RTX 4060.
As far as performance doing the Remove process in TPAI the GPU-Z sensor report shows pretty clearly that not very much of the 8GB VRAM memory is ever being accessed (approx 10-15%), and within the overall processing time of the image the GPU utilization only spikes up for a second, or two, or three. The slight differences in GPU engagement time is directly related to the position of the Speed/Quality slider.
Yes I thought it was a model car.
Tilt/shift lenses can give similar effects, these images were trendy a few years ago but not seen many lately.
Thanks. Radeon RX 6700 from my supplier is about ÂŁ330 for 12gb, so ÂŁ30 more. But as it is not a standard fit in their ready made computers, it will cost around ÂŁ100 more than the RTX 4060, so a no go for me. I"m already spending more than I want on this computer. The RTX 3060 12gb is around ÂŁ270 but again not a standard fit.
RTX 2070 Super seems similar performance to the RTX 4060 but the price was also similar?
I could get RTX 3050 for around ÂŁ60 less than the RTX 4060 but that does not seem a worthwhile saving.
