Today is a big release with the initial implementation of a new feature we are calling “Remove Tool”. This feature allows you to remove objects from photos by simply masking them out. To learn more, read the roadmap post:
Alongside this we have several more changes and fixes. As always, a full change log is below.
Installed, launched, worked okay - Win 11 Pro standalone & Ps 2024 plugin (via Filters menu & File > Automate). For now, CTRL/CMD + Z functioned like an Undo stroke for Remove masking. Like the no pulsing.
Thank you for your hard work.
The “Remove Tool” seems to be getting better than the previous betas.
Suggestion:
“Regenerate Button” within Remove Tool
Due to the characteristics of AI-generated images, it often requires a few tries to get the best result. At the moment, the ‘Remove’ button is grayed out after processing. To regenerate the masked area, it requires clicking on ‘Restore mask’ first and then clicking on ‘Remove’ again. I recommend changing the ‘Remove’ button to ‘Regenerate’ after processing (if there are no new mask area). So we can regenerate the masked area with a single click.
“Quick Export Button” within Remove Tool
I also recommend adding a quick export button within the Remove Tool. This way, if we want to save different generated versions, we won’t have to exit the Remove Tool before being able to save an image. We can simply use the quick export button without losing the last mask area, and then continue using the Remove Tool again without having to redraw the mask.
It might work if you select the remaining rubble with the removal tool in a second run.
If not, you can always create a “TPAI turns boat into fishing penguins on a raft” bug
(which is my personal fear, that future bug reports might go into that direction, draining resources from the other critical issues…)
On the Mac with sufficient GPU RAM this remove tool is in fact quite fast.
And overall seems to work very well here. Of course I had the one or other strange object inserted as well but there are ways around this.
And with an average of 4 sec per remove step it’s not really that bad if you have to do the remove several times for some object to get them right.
The timings I was referring to are using a RTX3060/6GB, Ryzen 9 with 32GB
At the moment I am on my other PC and this was run on a i7/16GB, GTX1050/4GB
Using AI for the sake of AI as using technology for technology’s sake is unnecessary. Convienence and speed are what I look for in processing my images.
With my 2070 Super (8GB VRAM) removal took a fair amount of time (minutes) to calculate, but used very little GPU power or memory. It did use enough that I could tell that the GPU was involved, but it was far from straining its resources. The end result looked pretty good actually.
Still no sign of the choice between 3 and 4 character extensions that was promised for Preferences->General some time back? (Unless I’m missing something?) Can it be added at some point please?
On the 8th of September Lingyu said (in the 2.0.0 release thread):
“We are adding a toggle in Preferences > General to allow switching between 4 letter and 3 letter file extension. However, 4 letter is recommended to avoid potential ambiguity. This will be released in 1-2 weeks.”
Yes, but this again is a very simple scenario where other tools without AI of course do work fine. a simple very well delined object on a quite uniform background.
This is not the primary target for this (and all other AI) remove Tools. Those are meant for complex situations in which the object to remove overlays a complex background (e.g. a building with doors, windows,…) where with the traditional tools you’d have much afterwork with the copy stamp - if you’ not have to solely work with the latter.
The Standard upscaling seems to have the same issue you got in GPAI 6.3.3 over 6.2.0, namely the habit of getting areas with pixillated noise-like effects… This is 4x and Standard:
Note the white line is the compare bar, it’s a screen grab.
Here’s Low Resolution for example:
