This week has some small but impactful changes. Most notably there have been two big performance improvements. Since 1.3.4 there has been a delay introduced between when the image is fully processed and when it’s actually displayed. This delay should now be gone, so it should act as fast as 1.3.3 was. On top of this, we’ve discovered a bug where panning the right side of Side by Side view would cause constant processing requests which would severely degrade performance. This should also be resolved.
Besides those two, we’ve also updated support for a handful of cameras. These cameras previously would output invalid DNG files, but now should save correctly.
As always the full change log can be found below.
I want to personally thank Topaz Management, for their decision to implement that requested Feature, and Software Engineers, for their talent to made it happen, as I know now, it’s “unusual” ratio for AI, and made it part of the Settings…. Bravo!
Honestly, I did not expect to see it so soon, as it required, probably, lot of efforts and time, but it just confirmed my opinion, I wrote in some of my posts:
Topaz team on the quest, despite all the bugs and quirks in a process, to develop Photo AI to the level, that benefit as many users as possible, in their workflow, that no competition can match.
Response time seems faster. Even if cycling through multiple categories of enhancement (denoise, sharpen, face recovery). I just installed & tried the Standalone as a 1st step. Win 11. Processor = AMD RX 6800 XT.
I seem to now be having an issue where I can’t use CTRL + W to close images anymore. It used to work. If I try a few times it works. But it used to work without several attempts. Can that be corrected? Thx!
It seems unusual that the default action of Ctrl+W is wanted to be changed as Ctrl+W is used mainly in tabbed apps with documents to close a window tab or document AND save a open document.
Photo AI has no tabs and only one window.
It would also be interesting to see what applications, image editors, actually use Ctrl+W to close the application as it should never be used to close an application.
Alt+F4 is the default to9 to close top level window and ask to Save the open document as you can see in most apps including Photo AI.
There is no “Cancel” button in the (Ps) Plugin version for PAI and CTRL + W is the easiest, fastest, hotkey method to exit the plugin and return to Ps for me. I can hit the key combo without having to go all the way (exhausting… ) to the upper right to an “x”.
Alt + F4 completely shut down PAI. A no no while I’m working.
Ctrl + W only closed (after multiple attempts…) the open image (the only thing I want to close, not the full program).
After that test, I remain with David - I’d like the Ctrl + W (Win PC) to close an image on the 1st use of that key combo (standalone or Ps plugin). And (greedy me!) I’d like a “Cancel” button in the Ps Plugin that lets me abort to return to the Ps UI w/out having to click the “x”. Just b/c it’s more “user friendly”. But the ‘work on 1st try’ Ctrl + W would be satisfying.
Request: When toggling Recover Faces on and off, retain the selection of faces.
Explanation: I have a scanned jpg photo with 2 faces, one of which is seen as “low resolution” by TPAI. TPAI autopilot selects 1 of the 2 faces. I manually Select All, and go on to fine tune the settings, including toggling the various filters on and off to find the best combination. The sections (Remove Noise, Sharpen, …) retain their settings when switched on and off - except Recover Faces. Turning Recover Faces off resets the selection to the autopilot selection. Please change this to retain the face selection.
Fred, that is not my question to Topaz or you. Topaz, in its last update mentioned specific updates to certain items - a DJI Mavic 3 (drone), the Nikon Z8 mirrorless camera, etc. Exactly what Topaz means is a question. Products like Lightroom and others have specific setups for many models of cameras - taking advantage of that camera’s abilities and putting them into a module for those specific camera users.
You were the one whom mentioned the D810 being covered by Topaz for a while now. Yes, Topaz products do work well with the D810, but no specific mention of “modules” to the D810 itself and not just coving the D810 along with 100 other cameras.
Why / how would I have a link to something I was asking about and then you chimed in with your comment? If anyone should have a link, it would be you as you commented that Topaz has worked with the D810 for a long time.
