This week we have a handful of updates related to different cameras as well as some fixes for some annoying issues.
For general fixes, there should no longer be a large movement in the preview when zooming in/out for the first time. We’ve also fixed the Open Recents menu staying open after selecting an image on Windows, as well as adding an additional option to clear all recent files.
For cameras, we have added profiles for:
Fujifilm X-S20
Leica Q3
Sony ZV-1M2
We have also updated profiles for:
Canon EOS R50
Canon EOS R8
Google Pixel 2 XL
Google Pixel 4a Rear Wide Camera
Google Pixel 7a
Nikon Z 8 (Does not fix unsupported image issues)
Samsung Galaxy S23 Ultra Rear Super Telephoto Camera
Samsung Galaxy S23 Ultra Rear Telephoto Camera
Samsung Galaxy S23 Ultra Rear Wide Camera
Samsung Galaxy S23+ Rear Telephoto Camera
Samsung Galaxy S23+ Rear Wide Camera
On top of these profiles, DNG files with missing profiles should now no longer output invalid DNG files. We have additionally updated lensfun definitions to be up-to-date as of June 23rd.
As always the full change log can be found below.
v1.3.12
Released June 29th, 2023
Mac: Download
Windows: Download
Changes since 1.3.11:
Updated lens correction files
Updated camera profile support for various cameras
Added fix for unsupported DNG files not creating valid DNGs
Added Clear Recent Files option under File > Open Recent
Renamed Detail to Refine Detail in Remove Noise and RAW Remove Noise
Fixed crop on certain RAW images
Fixed images with invalid orientation causing issues
Fixed zoom not being centered on first zoom in/out
Fixed Photoshop plugin not correctly storing settings
Fixed open recents menu staying open after selecting an image on Windows
Known issues:
HDR or Monochrome DNGs which previously did not open may have issues when saving as a DNG
To get around this you can save as JPEG, PNG, or TIFF which shouldn’t have the same color issues
Keeps getting better.
1.3.12 seems so much faster than the previous versions.
Still hoping to see support for the M sized compressed RAW Sony A1 files. I guess I can process the RAWs elsewhere and then run them through PAI until then.
Hello,
thanks for the good work. Will there be updates to batch processing and CLI features in one of the next releases? (I am hoping for that every release, but the focus seems to be on smaller bugfixes, cameras and models).
Batch and CLI in their current form are not usable in a professional way when working with hundreds or thousands of images.
One cannot set what models to use for Batch Processing Autopilot (or alternatively disable specific models). Most of the time when batch processing one knows exactly what kind of images are going to be processed (computer generated, photos, and so on - but there is no way to specify that; it just autopilots over it…)
See Additional preferences for autopilot and Is there a way to disable models?
One also cannot really batch process using the “Apply to all” feature, as it doesn’t only copy the selected models, but also the image specific values it detected for the first image to all other images (instead of re-detecting those values like sharpen strength / sharpen clarity / enhance suppression noise, … for every image)
See How can I apply current settings to all loaded images without their values?
Since “Apply to All” is not really usable, one has to click on every image manually and change the models. But the film strip UI is not build for that in any way (if you have hundreds or thousands of images you can forget it). Gigapixel had a much better UI for batch operations and multi-value changes:
See Port the spreadsheet style interface that gigapixel had as a UI option
The CLI is unusable as an alternative, as it does not allow specifying models or options.
Instead it will autopilot every image and then you’re no better off than having used the UI.
See Photo AI CLI - allow arguments to influence settings
Will any of these issues be addressed in one of the (near) future releases?
Thank you, it seems that .12 release fixed the instability of previous release (that was not after all NVidia driver issue).
However, it seems that .12 has somewhat increased tendency for artifacts (see attached image). This is from the Standard sharpening model and occurs with practically all stength and clarity settings (crop from the bokeh area of image, ORF-file).
This release and the previous few seem to me to be retrograde steps in terms of colour. You almost had the RAW conversion producing a Gretag chart that was usable, but recently it has returned to poor.
What became of the additions promised for release many weeks if not months ago , the rotation for crop to correct horizons ? Seems to me that at the time that you removed the option to upload our images to your development of AI , the addition of new abilities ceased.
I can confirm that this new version has indeed fixed the violating zoom bug when zooming in on a new image for the first time. This version also seems to be a little faster than the preview. Another very good point. I haven’t tested all of this new version yet, but on what I have already tested, it’s not bad.
It would be pretty cool to be able to have some preset options that one could use for a batch process.
I can see shooting an event and having several hundred shots to process at once with a similar look or one preset for the reception / another for outdoor shots / etc. all ready to go with a click.
Feature request: images captured using Nikon 200-500mm with teleconverter have a bit of a halo. This is rather a common use case, that teleconverter leads to softening/haloing compared to the lens itself. This is most prominent at the edges with bright highlights. Would be great to have the ability to correct for such effect.
there is already some sort of batch processing.
But I would prefer it to allow to copy the current parameters to only a selected pictures not to ALL pictures.
The fully automated batch is still not very reliable.
They should try to reduce the noise variably on different part of the image. The level of noise in the pictures are different (higher in the darker areas)
It complains about low disk space on C:, but I had previously (IIRC) set both the Data and Temp directories to a separate HDD and SSD respectively. However the option to set these doesn’t seem to be there any more - why? Can we have this as an explicit thing, in setup for the data and the program for the temp files please? (Or am I missing something?) I’m sure (see below) the models are still where I want them, not sure about the temp files?
Notes - I do have:
PAI_MODEL_DIR=E:\TopazData\Topaz Photo AI\models
Which only exists while the program is running, and seems to drag in crashpad and logs at the same level.
Despite all the updates to TPAI, I still think that the original softwares often do a better job, even though they have not been updated in months.
I took another look at a shot I took a few years back, where the foreground rocks were hopelessly out of focus.
In both cases, I used the out of focus model cranked to the maximum and also had to spend a lot of time refining the mask. This was slower in TPAI, since there is no edge aware tool and the AI brush couldn’t handle the transition between the rocks and the waves on the lake at all well. In fact, in both cases that was the most difficult refinement to achieve.
Even in comparison view, one can see far more detail in the SAI version on the left. The TPAI version also has a pink artefact.
Hi
Today I refreshed my Topaz Phot AI to v1.3.12, but the result is strange.
I seems the system doesnt work or something wrong with the preview.
(But I made processing and it doesnt finish it after several try)
