Photo AI does not seem to respect the crop I perform in Capture One. It also does not allow me to crop within Photo AI
Are you sending a RAW file or using Edit to send a TIFF, PNG or JPEG?
If you are sending the original RAW image it wonât know what adjustments you have applied.
I am sending RAW file that has been cropped, using âprocess withâ as previously directed.
Hi! Sorry to hear about the crash. Can you please send me your log files from 1.1.8 Help > Open Log Folder?
Hi Biron - If you can send me an example of this, itâd be very much appreciated. Please let me know if youâve sent me something through: Dropbox. Thank you.
Hi - can you please send me some of the original images where their processed DNGs donât have some of the metadata like lens information? Please let me know if youâve sent me something through: Dropbox. Thank you.
Hi Ulrich - I see you sent into our Dropbox some CR2 & CR3 files in the past. Are those the samples that are having that issue? Thank you.
Hi - if possible, please send me the image through Dropbox. Thank you!
Archive.zip (997.0 KB)
Hi, meanwhile I raised a Ticket and asked for a Dropbox Link to send the resulting DNG as well. Or should I use the link at the top of this thread?
Regards, Ulrich
Hi - you can just use the link at the top of this thread. Thank you!
Hi! Iâd appreciate it if you can send me an installer log file by doing the following:
- Open Terminal on your Mac
- Type in (you can copy and paste it): grep -n âinstall-pspluginâ /var/log/install.log > ~/Desktop/topaz-support-installer.log
- Press Enter
- Go to your Desktop
- Upload âtopaz-support-installer.logâ
I use the new upscaling models in Gigapixel AI 6.3.2. Has anyone compared the quality of upscaling between GAI 6.3.2 and PAI?
Downloaded the Windows file and installed over the older version without any problem. The activation is new but went ok. v1.1.8 works well but I see that there is still no rotation in the crop tool. The all in one PAI is shaping up nicely.
I donât believe that other applications can read a local crop applied to a RAW image in Capture One as they are held in either a catalog or session.
You will need to use Edit with, rather than Open with, sending a file with the Capture One adjustments applied.
Through V1.1.8, an A/B comparison of a DNG input file, and JPEG output file (95% quality) shows a definite loss of contrast. Iâve seen this in earlier versions of Photo AI, too.
The DNG is generated by PhotoLab6 (now V6.2.0, but the difference is also seen when using earlier versions of PL6).
Is there a way to u/l the DNG as well as the JPG?
The DNG and JPG are being viewed with either PL6 or Irfan 64 V4.53.
The problem isnât limited to Photo AIâŠ
The left side of the image is a PL6 DNG file, the right side is a Sharpen JPG file. The montage was created with GIMP 2.10.
The shadows in the cactus, in particular, show a loss of contrast, while the overall bokeh field is darker.
Digging further, I was very disappointed by the histograms for the Sharpen output:
compared to the DNG input:
Sharpen compressed the dynamic range far beyond what makes any sense to me.
Appreciate you guys added the custom scale multiplier. <3
