Ultrich - could you send me this image and the NEF file you posted about later? If you could also send em your log files, please. You can send it to the same Dropbox folder.Thank you.
Thomas, if you can send me this image too, thatâd be great. Than you.
Hi! This has fixed the preview navigator being pixelated with some images.
Done! Filenames starting with UP_
Canât use Photo AI because the minimum system requirement on Mac is macOS 10.15 - Iâm still using 10.14.6 because of some legacy software that is still used but has no updates available. Gigapixel, Sharpen and DeNoise AI all work on 10.14.6 so itâs a shame that Photo AI doesnât support the same system requirements as the existing software.
You should be able to upload images in posts now
Thanks, Rod. Iâve got the images. There are still improvements weâre going to implement for Autopolit before the official release. You should also be able to add images to your posts now. Thank you!
Despite choosing different paths for program and model it installs to "C:\Program Files\Topaz Labs LLC\Topaz Photo AI" (program) and âC:\ProgramData\Topaz Labs LLC\Topaz Photo AIâ (models and other data)
Thanks Yazan for setting me up to add images to my posts. Iâm sure there will be many improvements to AutoPilot, but you really are off to a good start!
_F9I8088 &
_F9I9065
are up
Okay⊠Mac Mini M1 16G ram, latest Monterey
Lightroom Classic, plugin, sends Tiff to PhotoAI⊠The PhotoAI preview image is definitely color/brightness shifted⊠but when you save it back to LR, itâs notâŠ
In Auto the sharpening is also less effective with whatever model itâs using than anything that SharpenAI doesâŠ
I like the interface with the section that tells you what it did⊠but I really donât see a place where Iâd use AUTO for stuff without the ability to tweak one of the 3 variables, Noise/Sharpening/Size as good as AI is⊠I see quite a bit of room for me to tweak vriables depending on the image and what I, as a photographer, that I think I need to tweakâŠ
Thanks for the feedback! Can you please send me that image where Face Recovery wasnât detected?
Weâre working on improving the installation process. Itâs currently taking much time to install the models for all the filters but weâre looking into ways to have it install faster than the way it currently does.
You shouldnât be getting these artifacts. Photo AI doesnât currently have a trial mode and even if we had, the watermark would be our companyâs logo. Are the artifacts present in the updated preview or only in the output? Iâd appreciate if you could send me the original image through Dropbox and share with me or send me a screenshot of the model & settings you used (unless you processed with Autopilot). Thank you!
Can you please send me one or two images where this issue happens? A screenshot of the results youâre getting would be helpful too. You can share the files through Dropbox. Please let me know once youâve sent the files. Thank you!
Are you processing in the app in standalone or are you using it as an external editor somewhere? If youâre using it as a standalone and youâre getting this error, please send me the image and your log file from Help > Open Log Folder from the same timestamp of the failure. You can use our Dropbox to send us the files. Thank you.
Thanks, Don. Can you please send me this image? Itâd be helpful to have as many images as possible in such cases as weâre improving the Autopilot. Thank you!
Thank you. Weâll address both of these
Autopilot is currently not detecting faces in some images. Weâre working on it. Can you please send me the image(s) where Autopilot didnât detect faces? If you can also send me the image where DeNoise added too much sharpening, thatâd be great. You can send the files through Dropbox. Thank you.
