And if, for example, you could make Gigapixel and Photo share the same template folder? That alone would save a little over 30 gigabytes.
A small improvement to an image generated via Flux2 Dev in 2K. I edited it in 8K using several passes and variants with the Wonder 3 medium and max models, Wonder 1, Recover v3 max + recover face, also used Standard max at 100%, Low resolution v2 all in 4K and the last pass towards 8K with a Wonder 3 medium pass and a Standard max variant which I mixed.
The result is really nice. Okay, some details are a bit lost with WebP compression, but without compression, it’s very detailed.
Are you able to reproduce this consistently? This is probably just a visual bug
I’m going to stick with an image to see if I can reproduce it.
I just tested it again. It’s possible it was a visual bug, because it didn’t happen again when I repeated the same test.
Probably a visual bug then, reach out if you discover how to reproduce ![]()
Okay, no problem. Right now, I don’t have any more images to rework, but if I ever see this visual bug again, I’ll tell you exactly how I fixed it.
Hello everyone!
v1.3.4 has been released, with the new Wonder 3.5 model - Check it out ![]()
