Topaz Gigapixel v1.3.4
Hello!!
A new update of Topaz Gigapixel is here with more improvements and fixes.
Windows: [Download]
Snapdragon: [Download]
Apple Silicon Mac: [Download]
Intel Mac: [Download]
Released August 13, 2026
WONDER 3.5 is here!
If you’ve been exploring our Wonder models, Version 3.5 is a straight upgrade — same tool, same speed, just better output.
Here’s what changed:
Images come out crisper with more genuine detail, and that repetitive/patterned look you’d occasionally get is much less common now. Noisy source images also get handled more gracefully.
The real difference shows up when you’re working with rough source material — think low-res or heavily compressed photos. 3.5 pushes harder to recover real detail and legible text from images that used to be tough cases. Tables, charts, and other structured content also come out sharper and more accurate than before.
Everything else you already do well — portraits, landscapes, wildlife, tricky textures — still holds up just as strong.
No new settings to learn, no speed penalty. It’s a drop-in replacement that just performs better.
We would love to see your before and afters using this newest version. Share your results and let us know how we can keep making this model better.
Topaz Labs Watermark Available
Inside this update, we’ve now included the option to include the Topaz Labs watermark on your enhanced images. You can toggle on/off this setting in the Preferences menu under Settings → Export. By default this toggle is off.
Changelog:
  • Added Wonder 3.5 which supports local and cloud
  • Added ability to watermark images in export preferences (default off)
  • Added support for adding and updating provenance metadata tags
  • Fixed font display issue when app font was already installed as a different version
  • Fixed rare memory allocation crash
Nice! Excited to test W3.5 locally.
Also - 1st!
Wow!!! Really amazing Results! :blush::partying_face::tada:
Wonder 3.5 looks fantastic.
The details are much more separated and much more clean.
Wonder 3.5 (4x upscale) - Hifi V2 Background
Hifi V2 & Denoise Max (2x Upscale) - Hifi V2 Background
We may have to move your post to the “Bugs and Issues” section :rofl:
192MP limit has been removed :smiling_face_with_sunglasses:
The new model is very similar to Wonder 3 but with greater detail, especially in skin textures. In some photos, the difference is significant, while in others it’s hard to spot any differences. Wonder 3 was a very good model in most cases. Great update!
Edit: I successfully processed a 439MP image, and the result wasn’t bad, although it’s clear the model isn’t designed for this but I didn’t notice any loss of consistency across the different areas of the image.
Working on some random Wonder 3.5 examples! 4X medium strength with cloud processing:
My father’s mid-1940’s silver baby cup, CR2>JPEG source:
The printed back of a framed photo, CR2>JPEG source:
A small crop from a wider scene, this one is not so good:
Redefine>Realistic:
Standard Max (best for this one):
Two different crops from the same (digital) frame:
Digital source scenic:
Film scan:
What credit cost-?
More film scans:
iPhone photo – I think Wondoer 3.5 works best for film scans!
TBH I wonder if I should replace wonder3 with wonder3.5
I like legacy models staying available, might be some edge cases where 3 rivals 3.5 plus gives you something to compare to.
For your iPhone photo, did you shoot in JPEG or DNG? I always shoot in DNG. After editing in Lightroom, I run it through Wonder 3 and it works really well. Then I do a few more passes with other models to refine it even further. With this new update, I can’t wait to see the results. But I don’t have any more photos to edit right now, hahaha.
I tested the update on this photo:
Well, the best I could do was first to do a pass with a high Wonder 3 without scaling and then, from the result obtained, to do another pass with a high Wonder 3.5 with a scaling factor of 4.
Red panda
The result isn’t too bad. But anyway, for this example, you’ll need to do further passes with, for example, Recover V2 and Subtle Realistic Redefine with prompt to get something really clean.
Wonder 3.5 is better than Wonder 3 in every way, and I haven’t noticed any regression after testing it on dozens of different photos.
I think you should start thinking about removing some models. I don’t think many people use Wonder 1, for example. With Wonder 2 and Wonder 3.5, we have everything the Wonder models have to offer.
Everything is great so far :slight_smile:
But Hairs still look sometimes really artificial:
Did you enlarge 4x or smaller?
If smaller, try 4x and scale the image down, maybe ot turns out better.
Or run Denoise Max (50 - 70%) over it.
I enlarge 6x in this Case
haha good one!
HEIC, iPhone 12 (!)
@bin.sun
Is 6x Supported by Wonder 3.5?
Great examples!
There is still a cost for Topaz for all cloud renders; however, we are offering this for free as part of the subscription :slight_smile:
It’s supported on Wonder 3.5 and the previous versions too.
The maximum size still applies: 256MP. If the file is very big to begin with, 6x won’t be possible because you’re going over that limit
