Thank you for sharing the results
Feature request: allow Wonder 3 to render the number 5 ![]()
I like that
Some “before/after” comparisons with Wonder 3 + subtly realistic Redefine. With Flux2 Text2Image and Juggernaut-Z image generations:
Mecha zero: rainfall operation v1
Mecha zero: rainfall operation v2
Mecha zero: rainfall operation v3
Mecha Zero : opération pluie v4
So I changed the color of this one to give it an effect like in Tron.
The final result is really not bad because I then added a darker look and a bit of HDR which gives a bit of a Chat GPT look with its Image 2 model.
These are… new residents in Pairi Daiza?![]()
Hahaha no xd. ![]()
I hope so,
because with the prices of GPU today I won’t update mine before a long time. So if I can’t use your last models I’ll miss all the improvements, that’s sad.
By the way P5000 is compatible with RTX so it should not be a problem ? And I do think that I’m not the only one with an old fashioned GPU like this.
A family photo I’ve used in the past to see what the various models can accomplish.
Wonder 3
Standard Max with FaceAI 3
Earlier versions of FaceAI would try to add glasses to my wife’s great-grandfather, so version 3 actually is an improvement.
It’s not bad. But if you combine the enhanced super detail with Wonder 3 and facial restoration with Standard Max + Face Recover 3, you can get the perfect restored photo. Because I noticed that in the enhanced Wonder 3 photo, the boy on the far right of the image has the skin of someone at least 40 years old. Whereas in the Face Recover 3 photo, his skin texture is more natural and corresponds better to his age.
I would have but Wonder 3 pops up a dialog that you can’t use Face Recovery with it.
Technically, Wonder 3 has a Face Recovery feature included inside the model. As seen here, results from it can vary.
Thank you for showing the examples
After updating to this version anytime I try to use a model that requires the neuroserver it simply sits there doing nothing, or takes forever rendering an image without using the GPU at all. If i switch to another model that doesn’t use it that model will now not work , until i kill the neuroserver in task manager and then it will work. Any idea what that might be?
I have uninstalled and reinstalled a few times
I also had this same problem. Finally I found out that this happens when in the Settings > Face recovery > Parts to enhance is “None selected”. after selecting at least one item for this option the problem fixes!
am i the only one getting insanely slow speed after 1.3 update? macbook pro m4 max here…similar files before upgarde took like 1/10th of the time…i deleted model cache and mlcore cache
In fact, when I talked about mixing the two variants, I meant doing it, for example, in Photoshop or any other similar software in order to mix the best parts of both variants.
High Fidelity v3 works well, but it has a rather significant flaw: it doesn’t accurately reproduce the colorimetry of the source image. It introduces a slightly green tint. Visible here on the right.
And enabling or disabling gamma correction makes no difference.
Perhaps more visible on blue.
The original picture looks very nice too. ![]()
Thanks, quickie grab shot just for this exercise!
