Starlight mini didnt work
logsForSupport.zip (2.7 MB)
  2. Your system profile
For my part, it’s also happening… waiting for an official response.
See the steps that Darwin, shared from another post. The issue is that the model did not download correctly and you will need to do a clean install after removing everything from the current installation. This will allow the model to download again and correctly for your use.
