I have enable openvino. I remove my geforce 1030 because i need it not. i only test if it is faster. the info. i test also with gfx card, the processing time is always same with mask black and mask white display.
Application & Version: Topaz Sharpen AI Version 2.0.5
I was notified of the product update for Sharpen AI v2.05 and immediately elected to upgrade/update. Then Iâve spent the rest of the day trying to make it work with TOPAZ STUDIO 2.2. Finally, in exasperation, I elected to delete every instance of Sharpen AI in any of the directories including the Contents/resource folder. Sharpen ONLY WORKS as a standalone app. No matter what I do I canât get it to work as a plug-in. Even following the guidance provided to manually load the app as a plug-in proved totally useless. The icon shows up in the application but when I attempt to execute the app seems to open only to close not allowing any of the executable instructions. This is a mess and uncharacteristic of TOPAZ - there has to be a fix that doesnât require I have SW degree. HELP!!
Alan:
Thank you for your post. You saved me a lot of time.
After I received notification that there was an update, I downloaded and installed it and it worked fine. I closed the program and reopened it, it requested that I install the update. So I did, a couple of times.
Similar to you, I had two installations of Sharpen. I deleted both and ran the 2.0.0 update I downloaded. It showed that I had 2.05 installed. For grins, I closed the program and it requested that I install the update. I checked and I had version 2.0.0 installed. I installed the update again and now have 2.0.5 installed.
Thank you again Alan.
I am sure Topaz will fix this. On a more positive note, this version is amazing!
On a lark I went to my account purchases and discovered that Topaz Studio had been updated to 2.3.1 my loaded version was (from memory) 2.2. I did the download and install then reloaded Sharpen AI to 2.05 and my problem went away. Now when I Open Studio 2.3.1 everything works as it should and across all platforms including Adobe CC - my problem is resolved. Still donât know how I missed the update from 2.2 to 2.3.1 but now that itâs installed - I have to declare my issue closed AND NO THE FAULT OF THE TOPAZ TEAM
I really want to be able to try out Sharpen AI on my MacBook Pro 16" but every time I try to install it, I get a âcannot write to the directoryâ message. I have tried to change permissions to âread and writeâ, but it tells me Iâm not authorized. What gives? If I canât install the trial version, I wonât be able to use the registered version, Iâm sure. Arenât they one and the same? How do I make this work on the latest MacBook Pro hardware? This is frustrating!
Do you have studio installed by chance? There was one bad release of Studio (2.2.0?) that made some folders it touched owned by the root user, which makes any subsequent installs or modifications require root permissions as well. If you did, I would contact support and they can walk you through fixing that.
I just installed the trial version of Sharpen AI this AM. It seems to process the images, but than gives me an error message: Failed to save file . Iâve tried it several times and get the same message. Is this a limitation in the trial version?
I too test the trail version. save should work. but remember if you have the windows defender ransomware protect on you need add topazsharpen to the whitelist or you get save errors
Hi The latest version is not taking .psd files. Only taking .jpg files. also need tutorial/help to use the new version of this upgraded versio,.
Thanks
When will the errors be fixed so SharpenAI 2.0.5 is usable (i.e 50,50 values which will be the same values in auto mode). I sent a video with all issues some time ago to demonstrate it but so far nothing happensâŠ
Hi Don, I recorded a screen video with log files for Eric. It demonstrates clearly when doing the following steps:
SharpenAI starts with default values 50,50 (it was 15,15 in version 1.x)
hitting update to sharpen the image
when you then switch the mode to âAutoâ and you hit update nothing happens as the values donât change"
when you switch back to manual the values are still 50,50 and pressing update does nothing as no values change
if you set the values manualy and press update the process starts and the image is processed
if you then select Auto mode again you can clearly see that the sliders jump back to 50,50 and pressing update process the image again
if you then switch back to manual the sliders are also back to 50,50
if you then press update again no processing takes place as no values changed since auto processing.
My screen recording shows it clearly. I did the video a 2nd time to also create the log files for analysing.
Also with the 400% error (hitting update in 400% view distorts the preview and blows it up).
These issues are the same on two different machines (MacBook pro, iMac) running OSX Catalina.
So for me itâs not really working right now. Looking forward to an update.
OK it is a Mac specific issue on your PCs because on Windows it is fine and others on Macs donât have that issue either, it usually is related to the OS version.
