Problems with the Peview and Export V3.5.4
Here you see a preview and after that the same exported.
It´s a trimmed out 5 Second that i want export in order to test different settings.
I just set a higher framerate to 25 and this happens…
The exported video is 10 Seconds long beginning with 5 Seconds of darkness.
logsForSupport.zip (9.5 MB)
On 4.0.0.1b is happening the same when using the trim function…
Hello,
Is this still happening in the new 4.0.1 update?
Yes it´s still happening
Now when i export a 5 Second section(using the in and out marker) in the exported file is at the beginning 3 seconds of darkness and the overall videolength is 8 Seconds
logsForSupport.zip (21.1 MB)
