Topaz Video AI - v3.1.4 → Max Memory Usage 100%
AMD Ryzen 7950X
64GB DDR5
Nvidia RTX 4080 - latest drivers
Windows 10 x64 - latest patches
Usually get 9.2 fps when exporting with Artemis Medium on a 1080p video.
Is this normal? If not, how can I leverage the full power of my computer? Should I export multiple videos at one time? Would running via a SSD help at all in terms of fps?
Do you have two 4080s?
I don’t even have the option for All GPUs.
The only other thing I can think of is I have XPM enabled for my RAM, and in my tests it was slower with it off. But again, that’s DDR4 and the difference between 3200MHz and 3600MHz.
Appreciate you man. It doesn’t make any sense. I have everything possible in my machine to supercharge encoding, even have a better RTX 4080 than your 3080. I am at a complete loss.
Could it be the AMD Motherboard and Ryzen chip? Seems outrageous if it was.
This was with Encoder (H265 Main (NVIDIA) with mkv and 80 bitrate?
Okay. I tried NVENC:
On PNG the fps was constant. With NVENC it started strong, then slowed down quite a bit.
Here’s the times: NVENC then PNG
That’s just a 15 second preview. (Same result when I repeated NVENC.)
I am on Windows 11. And I haven’t updated my GPU drivers in about two months. (527.56)
Also wondering if you have some sort of anti-virus going on.
Umm I don’t use my C drive to process in TVAI… but I have done tests using it and the speed was the same… before the great speed increase update.
Try reducing memory % in TVAI settings to 10% or 20% and repeat test. I don’t know if it works for Windows, but reducing the max memory setting on Mac M1 below a certain amount somehow “forces” significantly more GPU usage and hence much better performance. I’ve no idea why it works, and sounds counter-intuitive. So perhaps worth a try, but maybe just a quirk of M1 / M2 Macs.
