All environment (windows and Mac)
Saving profile doesn’t save
- framerate in the video settings
- preferred Dynamic or Constant settings on bitrate in export settings
Try recreating the preset and clicking the “include preview & export settings” first before typing a name into the box. The team is looking into why some presets are not saving correctly.
Yes, this is exactly was I’ve done. This is not a regression, this issue is quite old.
Are you even aware that there is an outstanding bug where trying to click on “include preview & export settings” just makes the dialog disappear?
So you are asking users to do the impossible.
Was testing this today again and able to click the option and then type in the box without issue and have it save the settings as intended. The team is still investigating the previous issue where the dialog box would close as well.
