I think the issue is with your display and GPU driver. If you go to Device Manager click on display and let me know the details of the display driver.
What may also help is the type of display and the amount of Zoom on that. You can find that by right clicking on the desktop and select display properties.
If you open the Windowâs settings panel and search for âGPUâ it should pop up Graphics Settings. Inside of there, click âBrowseâ and find the executable for DeNoise AI (Default C:\Program Files\Topaz Labs LLC\Topaz DeNoise AI\Topaz DeNoise AI.exe). After itâs in the list, click it and set it to high performance.
Iâll attach images below of the steps. I donât know why this happens in 2.3.0, but we have a potential fix in 2.3.1 weâre still testing.
I had looked at the GPU Optimization change and clicked it off but did not switch to CPU.
2.3.0 works with your recommendations - Would really like to be able to use GPU but with low memory utilization - I ran into issues on an earlier version - until I set the GPU to low. I think Lr and Denoise were running me out of GPU Ram when using denoise as a plugin. Iâm running an RTX 2080 Ti with a Ryzen 3900 cpu and 64 gb of ram
Yea, LR is sh**ing the v-ram full for no reason, it only uses OpenGL for display. When you turn off GPU optimisation you can choose between high, mid and low v-ram usage in Denoise.
I use CPU/ OpenVINO. Tried external CPU, it is slower. Did this, but also slower.
Now I tried again, there are some pics working, and some not. If I have the problem that is no pencil for masking available, also the "auto update prieview doesn´t work ok.
Other pics (all the same Series, same Day, same Cam, same Lens) work fineâŚ
EDIT: Very Interesting: If I open the pic a second or third time, then all works fine. First time only sometimes.
Please send me a link for a older version, thank you
EDIT2: Now I âlostâ the pencil while I worked. Wanted nevertheless âApplyâ. Ther comes: Error: File not found.
In Sharpen AI all works fine
Thank you.
I updated my GPU, but I won´t use it because it isn´t at fast als my CPU. So I don´t think there will be any differences.
I will try this, and if the mistake will remain I use the older version.
Iâm really impressed! You shell out a new release with new license model and dispite some cosmetics like a new button for âLow Lightâ, some changed words and photos to make a test nothing substantial really changed to the better. As I wrote before the last 20 updates were all to fix bug introduced with bug fixes.
In short I saw the following issues are still there or new:
Automatic mode: Over sharpen especially edges with some rim light.
Automatic mode: Noise is not removed equally across an image. I will later upload image
Cursor in split view doubles and jumps back and force. Annoying
Where is the new comparison mode. I canât see it in my UI.
Where is this âMode without sharpenâ? I mean you could have set sharpen to 0 before as it is now mention. Nothing changed here. If you have the automatic mode set for a batch and you set sharpen to 0 the mode goes to manual and all images are set with the manual mode of the first image.
I thought the noise reduction is equal to 2.12 when doing the image with both versions to compare in PS. But then I saw that the new model must have gotten some changes as the shadows got plodges with the new model. Will show later.
You still can open DeNoise from the finder with an RAW file with âOpen withâ. You can then process the image like every other. You then can say apply (there is now save as in the menu for instance) and DeNoise show that it saves (or applies) the file. After several minutes when DeNoise is ready it closes as expected but there is now denoised file anywhere? Works as designed?
I havenât tested so far whatâs with the artifacts that Vers. 2 generates. Will do so when I have time.
I can confirm this problem. Using the keyboard space bar works correctly then not the left mouse button. I donât see any artifacting problem with using the Low Light mode (called Hi Fi model).
Iâm also finding that trying to move the image using the mouse hand doesnât work the first time (after the preview has been updated) and requires a second attempt.
The preview image can be stuck in the âoriginal imageâ view so that even though the process is being updated only the original is shown. I think this is related to the mouse moving problem. When the mouse is used to move the image but only once (so it doesnât move) the image will stay in the original view and clicking on another mode (like low light) doesnât change the preview.
Windows 10 PC GPU: RX5600 XT. Tested as stand alone.
Artifacting with Low Light mode occurs only when Enhance Sharpness is 0 - thatâs the only time Hi-Fi model kicks in. A workaround is to use a bit of Color Noise Reduction, but then color of the small objects (like eyes for example) might get shredded.
