====>> [CHECK THIS FIRST] 🚨- How to report a bug or issue for Photo AI
HOW TO OPEN A SUPPORT TICKET
If you encounter a new bug or issue with Photo AI, you can check our Troubleshooting page for some tips on how to resolve issues, and check our Known issues here on this forum. Each will have troubleshooting steps and workarounds if available.
If issues remain after checking these the fastest way to reach us is to write us an email at help@topazlabs.com. This will open a Support ticket with us and we will troubleshoot with you :slight_smile: In the email make sure to send us:
  1. What app you are having issues with
  2. The bug / issue and behavior you have encountered. Give as much details as you can.
  3. Any screenshots as necessary.
  4. Your system profile (Instructions for Mac ) or (Instructions for Windows )
  5. Your log files that you can find in-app, then go to Help > Open Log Folder. Zip all the logs you see and send us the zipped file in your email - If your app immediately crashes, you can skip this part as it will not allow you to get the logs.
SYSTEM REQUIREMENTS
Before sending us an email, it is important to make sure your machine meets the minimum requirements for our Topaz apps:
HOW TO CHECK WHAT VERSION YOU OWN
To check what Topaz app and what version of it you own:
  • You can go to your “My Products" page.
  • When you purchase your app, you get access to the current version available at that date, and access to 1 year of versions released after this date. Once that 1 year is over, the last available version will be shown in your My Products page.
  • You can also test and download the Latest version, however, to use it out of Trial mode, it would require to renew with another year of upgrades, that you can do from your My Products page.
HOW TO REVERT TO A PRIOR VERSION
All our versions are accessible here in our Photo AI Releases Page, or our Video AI Releases Page and or Gigapixel Releases page. Click on the version you want to revert to, and you will find the Windows and Mac download link at the top.
TO POST A FORUM TOPIC
If you want to post a topic here on the community Forum, you can. Other users can pitch in and we can also help investigate. Keep in mind that reaching out to us at help@topazlabs.com will be the best way.
Make sure to post on the correct forum, depending on what app you are having an issue with:
