2024-11-08-07-53-24.tzlog (41.0 KB)
I cannot get an image to export when using the redefine beta option. I have…
- Restarted
- Uninstalled and reinstalled (with restarts)
- Logged out and logged in
- Checked to ensure my GPU driver was up to date
When I go to export and start, I can see under system performance resources spooling up, then it peaks for a brief time, then goes back down and nothing else happens. I’ve let it sit overnight before and it won’t finish.
If I then try again immediately, it never appears to use system resources. It just sits there. I have to restart for it to try again.
One log file attached.
“Normal” exports not using beta work, though for this project I’m working on, I really need the better output the beta preview was showing (and previews work). It’s the whole reason I just bought this version.
Topaz Photo AI [v18.0.1] on Windows
