Using uncompressed PNGs 16 bit image sequence - original size 960x540. Total frames 586. Over the course of 20 or so upscales I have gotten the correct total once but all other times I only get 563 frames back. This was supposed to have been solved in 2023 but now seems broken.
Attempting to double the frame size with Proteus.
Considering I have “keep original frame numbers” selected, and those numbers end early in the processed frames, this means that 23 frames off the end are not being processed.
Splitting the job into two (two sets of frames in two different folders) nets 2 fewer frames than doing it all together.
I’m actually stuck and now past a deadline. I would upgrade to the a slightly newer version than the one I have but there is a history of upgrades not working at all.
logsForSupport.zip (1.1 MB)
