When I use frame interpolation, a strange flicker appears in the clip
Hello everyone, I’ve been experiencing an issue with frame interpolation where a strange flicker appears in my video clips. The flickering seems to be more noticeable in scenes with fast motion or complex details. I’ve tried adjusting various settings, but the problem persists. Has anyone else encountered this issue or have any suggestions on how to fix it? Any advice would be greatly appreciated. Thank you!
I have a MacBook Pro M3 MAX 64 Gb RAM
logsForSupport.zip (83.2 KB)
Is the flicker in the luma or lighting levels and noticeable in the highlights or shadows?
Are you able to upload a clip to show the issue?
I can’t post a link here how can I sent you a video?
If you are unable to post a link to the video here, you can send it to the support teams dropbox using the link below and then send an email to help@topazlabs.com with a link to this post so we can make sure to have the logs for reference.
Submit File to Dropbox
I have uploaded the file in the dropbox folder, you have the original one and the topaz render.
