Weird burn in created by the proteus model at upscaling to 4K
I recently tried to update a clip to 4k that was original 1280 x 720 resolution. The artemis model worked fine with 4k from what Ive seen, however my issue with Artemis is the surface smoothing created on the skin that eliminates texture almost entirely as opposed to the proteus model which appears to retain some texture and detail. So I reprocessed it with the Proteus model which created some weird grafting burn in that flashed in the film for 2 seconds.
Steps to reproduce issue:
  1. Upscaling 1280 x 720 resolution video to 4K
  2. Set to proteus model.
  3. Played with the settings which changed the burn in slightly and the duration it would flash in. But did not eliminate the burn in.
Topaz Video AI [v4.0.8] on [Windows]
Solution: I restarted the software completely and reran the Proteus model on the footage and it looks like it eliminated the burn in flash in that one particular area. So maybe it was an instance issue??
Something like this:
https://community.topazlabs.com/t/proteus-3-black-splotche-blotting/40072/20
Yeah! Thats exactly it!!! Thank you!
