Video will not export
Just updated to 5.1.1 on Mac Sonoma 14.5 and now video will not export. I selected one of my common presets and click Export and nothing happens. Prior, it would start the process with progress bar. Now, nothing happens. Is there a new setting or something I need to set or turn on or is this a bug?
5.1.1 Will not export…Please fix the bug ASAP, I’m losing time and work.
I have the same issue. I choose options like I always have and click export and absolutely nothing happens.
I uninstalled and reinstalled and rebooted. Export doesn’t work.
Can you share logs for review? Please check that the file is not being exported in the background and it is not being seen in the Export window correctly.
Can also check and make sure that the export file path has not been reset or cleared which can happen during an update. Logs will be able to show this if you can post them or send to the support team, help@topazlabs.com
It’s a bug as documented here:
Same issue here. 5.1.0 and 5.1.1 are definitely bugged. I can export individual files using some trickery as outlined above, but not multiple files like I used to. I have to click on each input and send to export one by one. I downgraded back to 5.0.4 as a workaround. Not good, Topaz. Quality control has never been a strong suit there, but this never should have made it out the door. For not one, but two, releases, mind you.
