Hello Dan and everybody,
I have similar, maybe even identical errors. I downloaded the production version 1.0.1.
Error # 1. The program cannot detect the GTX 1070 GPU (on Win 7, 64-bit).
BTW: I use Python + CUDA 8 because I am also a developer and my programs work with GPU very well.
Video Enchance AI 1.0.1, on the other hand, only “worked” in CPU mode.
Error # 2. I wrote in quotation marks because the program renders frames, but then doesn’t save them anywhere. The effect can only be seen in the preview window, not on the disk.
I tested small and large images. As a source I used my graphic works, files of the .png type. To shorten the rendering, I made the animation for 2 frames.
Error # 3. Like you, after pressing “Stop” before finishing work, the program hangs (crashes) and you need to remove it manually from Windows tasks.
! Interesting fact: I tested the program several times (from 672 x 605 px to 2376 x 3780 px).
, and
only one time the program saved the resulting .png images. The result is very good. I tested my work, a little boy’s drawing
Unfortunately, I can’t repeat it because I changed parameters and order randomly (e.g. preview first and then normal, then vice versa). However, in normal mode I could not force the program to do “save pictures” - neither in “preview” nor “normal” mode.
(I used the “Process Monitor” software to check if the program saves ANYWHERE images to disk, unfortunately they are nowhere to be found
Conclusions: the program has a revolutionary idea, but you have to refine it technically because it works on some systems and not on others.
Regards,
Lech
