The bug / behavior you have encountered
Your system profile
Your log files (Help > Logging > Get Logs for Support)
Any screenshots as necessary
When exporting a film with SLM, I sometimes have the effect, that the output film is running much faster as the input file says. The sound is correct speed and pitch as the source, but the picture is faster.
This is the input file:
As you can see, input fps is 29,97
After processing with SLM the “end”-screen looks so:
Playing the original file, the file length ist 04:21 with 29,97 fps:
Playing the with SLM enhanced file is 04:21, too, but the picture is ready at 03:28, the rest is just music. No pictures missing, but speed is way too fast:
It doesn’t matter, which player I use, the picture of the film is always ca. 1min. too fast, that’s nearly 1/3 speed up!
It’s the same effect on two systems with NVIDIA RTX 5060 ti, Intel 8700K, Asus ROG Mainboard, 32GB ram
What could the problem be?
A lot of other films are working correct.
