Video AI 6.1.3 Chronos and Chronos Fast exporting wrong frame rates
    I have a source video with an unusual fps of 23.919. Using Chronos or Chronos Fast to convert it to 23.976 or 24 fps results in files with odd frame rates like 7.99, 9.99, 19.98 or 29.97 frame rates. This is regardless of the Duplicate Frames setting.
    Screenshot 2025-03-10 at 8.01.56 PM
  2. Your system profile
    M3 Macbook Pro, Sonoma 14.7.1
logsForSupport.zip (324.4 KB)
Thank you for sharing the screenshot and the logs for this issue. I have having the team take a look to see what is going on and will update once they have found something.
Thank you. I forgot to mention this issue seems new to the latest version 6.1.3. I don’t recall exactly which version I had before but when I launched recently it said 2 updates were available for me.
In the previous version I was using I had no issue converting frame rates, though my sources were starting with normal frame rates like 23.976 or 24.
