"Upscale to 4K" preset does not work as intended?
“Upscale to 4K” preset in Topaz Video AI v.4.1.0 is not working as intended.
When selected, it either:
  1. Does not do anything if no changes have been made to the Export settings.
  2. If changes have been made to the Export settings, then choosing “Upscale to 4K” resets the Input parameters to the default.
Steps to reproduce:
  1. Input any video, let’s say 1920x1080 at 30 FPS
  2. Make changes to video, i.e. set export to 3840x2160 and 60 FPS
  3. If you choose to select “Upscale to 4K” from here, the video will default back to the input settings of 1920x1080 at 30 FPS.
Expected behavior:
Case 1) Preset should appropriately apply the desired resolution (4K in this case) instead of doing nothing.
Case 2) Settings should not revert back to the original input.
This has already thrown me off a few times, admittedly.
I haven’t tried this particular preset, but I only ever use any preset as a starting point and make my own changes to suit my needs. I always end up with a few variations and just give them sequential numbers after the name so that I can decide which is doing the job for me. I think the existing presets are basically a ‘one size fits all’ approach as everybody’s needs will depend on several factors and maybe there’s a setting in the one you’ve mentioned that doesn’t mesh with the specific source material, etc.
cuando pongo mi present me sale la resolucion normal pero deveria estar en 2x pero cuando lo hago update para regesar a su resolucion como estaba y me salgo de topaz y sigue el problema de poner normal en resolucion y no en 2x y eso paso con la mayoria de mis present
necesito ayuda con este problema por favor
The team is aware of presets not working correctly when it comes to changing the resolution. They are working to resolve this issue as quickly as they can.
El equipo es consciente de que los ajustes preestablecidos no funcionan correctamente a la hora de cambiar la resolución. Están trabajando para resolver este problema lo más rápido posible.
Steps to reproduce issue:
  1. Step 1 Original batch videos at 1080p 29.9fps
  2. Step 2 Choose to upgrade to 4k 60fps
  3. Step 3 Output automatically readjusts fps back to original video input
  • creating a preset, saving it.
  • when calling a preset, everything else is saved but output resolution and FPS, these will remain as the original.
  • changing those and updating a preset wont help: when calling a preset, the same anomaly occurs.
Cleaned the Topaz install and reinstalled everything. Nothing changed.
i7, 13700K
64GB RAM
M.2 2TB Samsung EVO Pro SSD
RTX 4070
Win 11 PRO
This should be fixed in v4.1.1 please update to that version.
