New Photo AI user here. I opened a small file in photoshop (2k x 2k) and tried to use the topaz filter to upscale. But in the upscale pop out window, the pixel numbers cannot be edited. No way to enter in a new size. I can change units, but not enter numbers. The sliders work fine, but there’s no point to that if I can’t upscale.
I can use the standalone Photo AI with no problem, but I’d like to use the PS filter too for quick, lower-res edits. I just updated to 2.4.2, and same problem.
This is on my PC. Very fast machine and GPU. I often work with files around 20GB. Haven’t checked it yet on my macbook pro.
To upscale in Photo AI when invoked from PS you need to use the File>Automate method - if you try through the Filters menu then upscaling is disabled in Photo AI (an Adobe limitation).
Hey Paul, neither GP or TPAI have worked for me trying automate through. I can see them but when I attempt to use the link it closes PS. Any suggestions?
