Is this preset still available? Sadly the links don’t seem to work anymore…
I think these presets by TomaszW should be preinstalled in the program.
I’ve been to that folder, but there is no “presets” folder at all.
the links still work for me
Good morning . have a link for dvd—1080p preset. THANKS
Thank you for your prompt response. I will install it tonight. THANKS
I’m waiting for your opinion on my presets Thanks
Hello . I can’t get kes installed. I copied them into the directory c:programme/topaz labs llc…/topaz video ai…/. and even create a presets directory in this last directory. turn off and restart windows but they don’t appear in the topaz preset tab. I was just about to try
Thanks
To use the preset all you need to do is copy the files (JSON) to “%programdata%\Topaz Labs LLC\Topaz Video AI\presets ” (i.e. C:\ProgramData\Topaz Labs LLC\Topaz Video AI\presets ).
That’s very strange because for me this works.
it’s a shame. I restarted my computer. but unfortunately it doesn’t work. we will find a solution … thank you anyway
Yeah, that’s me
lol. you didn’t like your old name?
Not specifically, but it’s an account I haven’t used since I created this topic, and I no longer prefer to use this first account that I had created since the appearance of VEAI
Thanks, these are a great starting point for upscaling some low quality extended play VHS captures I have. Better than the Mac upscaled and the Samsung QD-OLED and LG OLED upscalers. Source is 704x480i 15Mb/s MPEG-2 captures. I then deinterlaceds with QTGMC with BOB and fed the 480p/60 to Topaz. Upscale is 1440x1080p.
I turned off the Stabilization as it was not needed. I will start playing with the Sharpness and Deblur to get better results.
Now that v4 is out is there any chance you’ll update new ones?
