TVAI 5.1.1 Stable - AION model "error": conversion don't start!
It’s still running out of memory, looks like your memory limit has been set back to 100%.
You have not understood the situation well:
this NEW error is not related to my “work PC” where I mount an RTX 3070 with 8GB of VRAM (and in that case I solved it by limiting the memory usage to 80%)… but this new error appeared to me with my gaming PC which is completely different, in fact it mounts a RTX 4070 Ti SUPER with as much as 16GB of GDDDR6X VRAM with 256-bit Memory Interface Width (the same used on the RTX 4080)… so I would say that it is therefore IMPOSSIBLE that it is a problem of lack of VRAM!
:melting_face:
What is the source of the problem this time?
You clearly need to fix an underlying problem with this new AI engine!
Can we try with an 80% limit set?
Tried it now–SAME PROBLEM/error!
JakSpoon 4070TiSUPER 80 memory - logsForSupport.zip (702.6 KB)
ffmpeg "-hide_banner" "-i" "C:/Users/Jacopo/Videos/DRAGON BALL Sparking! ZERO  Gameplay Showcase ENG.mp4" "-sws_flags" "spline+accurate_rnd+full_chroma_int" "-color_trc" "1" "-colorspace" "1" "-color_primaries" "1" "-filter_complex" "tvai_fi=model=aion-1:slowmo=4:rdt=0.01:device=0:vram=0.8:instances=1,scale=out_color_matrix=bt709" "-c:v" "hevc_nvenc" "-profile:v" "main" "-pix_fmt" "yuv420p" "-b_ref_mode" "disabled" "-tag:v" "hvc1" "-g" "30" "-preset" "p7" "-tune" "hq" "-rc" "constqp" "-qp" "17" "-rc-lookahead" "20" "-spatial_aq" "1" "-aq-strength" "15" "-b:v" "0" "-map" "0:a" "-map_metadata:s:a:0" "0:s:a:0" "-c:a" "aac" "-ac" "2" "-b:a" "192k" "-map_metadata" "0" "-map_metadata:s:v" "0:s:v" "-movflags" "use_metadata_tags+write_colr" "-metadata" "videoai=Slowmo 400% using aion-1 replacing duplicate frames" "D:\VIDEO\TVAI Stable/DRAGON BALL Sparking! ZERO  Gameplay Showcase ENG_1_aion1.mp4"
Just tested this out and was able to export a portion of this video out with those settings without an issue. I did not run the entire 12 minute long clip.
CPU: i7-8700K 3.70 GHz
GPU: Nvidia RTX 3060 12GB VRAM - Studio Driver 15.4601
RAM: 64 GB
SO: Win 10 home - 19045.4046
If you see in the post above… I shared the screen of the program after the error: the failed video conversion is referring to only a portion of the video (it’s not the full 12 minutes, but only about 4 minutes)… and I have this problem, I repeat, with a high-end GPU and with 16 GB of GDDR6X RAM (even setting the program to use 80 percent video memory)… I would say there is a BIG problem underlying this frame interpolation model!
:expressionless:
Just as some additional input, I happened to do some upgrades to my cooling so I could add more RAM, and it seems like after I tried Aion with 64GB system ram (16GB VRAM), I can use Aion without problems. I see that JakSpoon lists his system RAM at 32GB.
In fact, good Tony was talking about a “memory” problem… but it seems really strange to me that it’s a problem of little RAM installed on the PC:
TVAI uses very little RAM even with the heaviest tasks… and I don’t see this as the case with a PC with “little RAM”… 32GB is the medium-to-high “standard”… expecting to be able to encode a video in AION just by having 64GB of RAM seems to me a really excessive requirement for the vast majority of people!
As user @Imo said, the problem is not the amount of RAM at all: according to him, he has 32GB of RAM and had no problems using the AION model!
I have same problem.
Aion model stops working.
It works only when used without any other model (like proteus and etc).
And another requirement is that fps change should be > 2x.
For example when 24000/1001 fps converted to 60 fps - it works.
But when 24000/1001 fps without change (with duplicates replace enabled) - it fails.
Also if convert to 30000/1001 fps it fails.
And looks like it is realy a memory problem. I have 8GB vram (nvidia 4060ti).
When memory limit is set to 80% then it fails even with 23.976>60fps conversion.
@tony.topazlabs @Imo @kyle.topazlabs
I continued testing with AION, in combination with the latest stable version 4.2.2… and although I have generally noticed improvements, the “problem” I am experiencing is still there, and I may have figured out what it may be due to:
I tried another video, this time I used this one (downloaded in both 1080p AVC 60fps MP4 and 4K VP9 60fps MKV, both not in HDR version, using the 4K Video Downloader+ program):
In doing various tests, I discovered two things:
  1. With my RTX 4070 Ti SUPER 16GB of VRAM, the problem obviously cannot be insufficient video memory: in fact, encoding the video in 1080p with AION 6x, Windows marks me that the program uses about 6GB of VRAM, while in 4K it goes up to 9GB).
  2. The problem occurs (it seems) ONLY when I select a part of the video to be encoded (with the “mark in” and “mark out”), while it seems not to occur when I encode the whole video file: I’ll tell you more… now selecting the part to be converted, when it goes into error, and I re-start the ecoding with the “resolve error” button, it restarts the conversion but this time it converts the ENTIRE video: in fact the encoded video is the total starting video, not the part I selected.
At this point it seems confirmed that it is a BUG of the program coupled with the AI model when choosing to convert only a part of the video!
:melting_face:
I ask you to fix this issue as soon as possible!
JakSpoon AION problem TVAI 422 - logsForSupport.zip (442.8 KB)
JakSppon - DxDiag v2.txt (104.1 KB)
I have run some tests with mp4 files, and I am continuing to do so with other files that I am setting an In/Out marker and exporting using Aion and so far, they have all worked. Going to convert a few files into mkv as well and I will get back to you on if I run into the same issue.
DxDiag 4-2-24.txt (115.1 KB)
Just wanted the add that I am having the same issue. I cannot preview or export any video using AION Frame Intropolation without getting an out of memory error in the current release or the beta version soon to be released. I am on a M1 Max 64GB Sonoma 14.4.1
Update on the situation:
I believe that nothing has been done by the developers to at least “try” to solve these alleged video memory “problems” for the AI model “AION”… despite as I said I have a HIGH end computer (Ryzen 7 7800X3D + 32GB DDR5 6000Mhz dual channel + RTX 4070 Ti SUPER with 16GB of GDDR6X video memory), I keep having serious problems with this AI model: let’s say that with 1080p videos the result is fluctuating (I have to admit that it “seems” that with the new versions the problem has subsided, often I was able to convert 1080p videos in slow motion at 6x, but not always). … but today I tried with an AVC video in 4K at 30fps and, with the latest stable version 5.0.2, the encoding process froze just before it started, it gave me error immediately!
As always I attach the LOG file created by the program!
JakSpoon AION error TVAI 502 - logsForSupport.zip (533.9 KB)
I hope, dear developers, that you can solve it soon, because so many like me are in this situation, and it starts to be really frustrating!
When I input video ratio less 2160P (eg. 3840x1600) have error same as yours, I try upsale ratio to 3840*2160 error fix, I think Aion only can work in some default ratio
I really don’t think that’s the problem… it actually happens to me almost the opposite: lately with 1080p 16:9 standard YouTube H264 format videos I haven’t had any particular problems… while for 4K videos, I always get errors and the encoding crashes right away!
I simply believe that this model is not yet optimized and needs many refinements to improve compatibility with Windows hardware (in fact, NVIDIA TensorRT GPU hardware acceleration is still missing)
I hope these problems will be fixed as soon as possible!
@tony.topazlabs @kyle.topazlabs
Dear @tony.topazlabs @kyle.topazlabs,
We have the same issue with a Mac M2 32GB Ram, trying to export with Aion x16
Error message appear at the end of the process.
But if you uncheck replace duplicated frames, it works …
There is thus a little bug in the software, but still it works without the “replacing frames” option.
Thank you for fixing it. All the best
Why is this not stated anywhere? Why is there no documentation on this?
And if this is the case, why isn’t Aion giving a memory error?
Thanks for the tip… I need to try as soon as possible to see if on my Windows 11 PC it solves the “problem”…
Let’s say it’s obvious that this AI model still needs to be optimized… so many users still say they have problems and the speed is REALLY so slow compared to other similar models!
Hopefully GPU hardware acceleration support for NVIDIA cards will be added as soon as possible properly…
Small, thankfully positive UPDATE on the issue:
for the last few days I have been doing some tests with 3-4 different videos (some already used in the past, some new, both at 1080p and 4K resolution): I can’t tell the reason, whether because of the new version 5.0.3 or because of the updated model, but FOR NOW every conversion done at 6x or 8x with AION has always resulted in positive outcomes, so the conversions have succeeded perfectly without giving any error (both whole videos and cut videos).
Have you done any “silent updates” to improve the AION problem? if so, this is the right direction :wink:
