TVAI 5.0.1 crashes during previews. If I run a preview of 15 seconds or over, it seems almost guaranteed to happen. Tried it on Proteus and Iris so far. This is the most crash-happy version of TVAI I’ve ever tried, which is disappointing, to say the least. I’ve not even got as far as trying a render, as the program is pretty well unusable for me in its current state.
Intel Mac, running Sonoma 14.4.1 (23E224)
Logs attached.
logsForSupport.zip (220.6 KB)
Looks like you could be experiencing the issue with the AMD card inside of a Mac that has been an issue for awhile and will require an update and patch from Apple.
You can try these settings in the Preference Panel to see if it helps resolve the crashing.
File>Preferences>Processing
Turn on low power mode
Set Max Memory to 50%
Max Processes to 1
Save those settings and try running the clip again.
