When I use the trim function to select a clip in the middle of the video, the audio is always way out of sync (by seconds sometimes). It seems to happen whether I scale fps or not, just a simple enhancement is enough. It seemed to work fine in one case for a 23.975 fps video in 3.5.3.
Hardware is Intel I7, RTX3060, Windows 11.
Hello,
Could you send us an email at help@topazlabs.com with the full log files from the app?
To gather logs, please select Help > Logging and make sure that there is a check mark next to File Logging. Next, recreate the issue and then return to the Help menu and select > Get Logs for Support and attach the “logsForSupport” file to your reply.
