The Error running model issues are fixed for users in v1.3.3. If issues remain on it - Send fresh logs and we can relay to the development team as remaining issue.
For Face issue: can you send fresh logs for the face issue in v1.2.1 - Dm or support@topazlabs.com - We have an open item with the development team for face detection issues, and the logs would confirm if its this issue or something else.
I just updated to version 1.3.3. Everything seems to be working correctly. There’s no longer any need to replace any files like aiengine.dll from version 1.3.1. All the models that previously failed to load, as in 1.3.1, now seem to work. There are no more loading errors .
Somehow, I feel that if posts are moved to different new threads without being curated (deciding what should stay here and what shouldn’t), it harms the conversation within the community.
Because a lot of threads just get lost in the mix.
Thanks for the feedback. This thread is to report specific issues about this specific release. For any other reasons, discussions, posts will be put in their correct category.
I never had to do this before, but for less headaches, uninstall your previous version from Windows 11 and install the new update that’s released here. Whenever I download the update within the app and have it install that way, the program fails to start again. Either it gives an error or “acts” dead when trying to execute the app to start. So I started uninstalling the previous version and then install the new release from this site and I’ve had no more problems and the new version(s) work great.
Updating form within the Application has always been a bit fickle so, as a rule I always do a fresh Install from either the Release Page or My Account and check for Driver Updates
Plus, there’s no need to Uninstall the Application before hand if you Install the New Version from the Release Page or your Account as this is taken care of Automatically during the Installation Process.
