Topaz Photo AI v3.6.1-3.6.2
Hello! We released a hotfix for 3.6.1 to fix quick preview in Super Focus. These patches also include support for new cameras, a major fix for preview on Mac, and other bug fixes.
We will continue to update Photo AI with additional bug fixes as needed to improve performance, stability, and the overall user experience in the coming releases.
You can find the installer links and the full changelog below for this version of Photo AI. For any issues, make sure to send us an email to support@topazlabs.com
v3.6.2
Released April 12th, 2025
Windows: Download
Mac: Download
Changelog
  • Fix quick preview not working for Super Focus v1 and v2
v3.6.1
Released April 10th, 2025
Windows: Download
Mac: Download
Changelog
  • New cameras supported
    • Nikon Z50 Mark II with Camera Profiles
    • Sony ILCE-1m2 with Camera Profiles
    • Canon EOS R100 with Adobe Standard Profile
    • Panasonic DC-GH7 with Adobe Standard Profile
  • Fix preview breaking on Mac with images larger than 15,000 pixels
  • Fix text with wrong color in warnings on Windows
  • Fix logging out trial users when switching between different applications
Lingyu Kong
Technical Product Manager
Image AI
Lingyu:
I just now tried 3.6.1. Unfortunately, this still does not fix my bug report about Super Focus 2 just producing a very blurry preview and result. :frowning: I reported this to support about 3.6.0 about 2 weeks ago. Super Focus 2 is totally broken for me. In our several back and forth emails Alexandre has been very nice, but she does not have any idea when or if Topaz will fix this. She said I am not the only one though. Do you know? Thank you.
The issue with Super Focus v2 on which Alexandre added your contact info currently has 14 users on it that have reported this issue. It is being looked into and only affect M2 Pro computers - As Dakota mentioned on the Gigapixel thread replies with you, this is being discussed with Apple and is related to the issue you are also experiencing with Gigapixel. As Dakota also mentioned, because they are actively talking to Apple to resolve this, there is no timeline we can give. We hope to resolve this as soon as possible!
We have your contact info on these open development team tickets and will circle back once those issues are resolved :smiley:
Super-secret hidden code uncovered by PAI 3.61 and earlier 3.60.
The first three images show, at different display mags, the hidden code discovered by PAI 3.60 in otherwise obscure areas of the booster.
The last image shows the same effect in today’s 3.6.1.
I wanted to make a 6’ high print as a gift to the friend who got me access to this launch. Can’t, with this hallucination weirdness.
We are working on a model update that should hopefully reduce these artifacts. For now, I would recommend deselecting areas of the image that have artifacts in Super Focus v2.
Thank you.
From reading the Super Focus 2 info when 3.6.0 was released it talks about being much faster than Super Focus 1 and also that it is more flexible because you can make some changes without re-rendering. What is not clear is if the results are exactly the same for 1 and 2. Are the results the same, but 1 is slower and less flexible?
@Lingyu @Ange.topazlabs
I don’t remember… Is the Panasonic DC-G9M2 already supported by the program officially? Are its 16-bit RAW files read in the correct way? (The GH7 should also have the same sensor and thus the same “files”)
This one does indeed seem to be fixed.
(At least for me)
Thanks!
One more user who detected a “secret code” in a .HEIC image. It seems, this kind of artifact appears mainly in otherwise unstructured areas of a photo.
We’re all waiting for the update, of course.
As long as it’s not a countdown…
That would at least make me a bit worried. (And I would put any important possibly world-changing research I’m currently doing on pause) :face_with_hand_over_mouth:
@michael-3397 - Adding to Lingyu’s message, can you confirm if the artifacts occur if you use Super Focus before it’s sized up? Seeing it’s already 14000 pixels. Can you test Super Focus on the original, then once Super Focus done Upscale? Let us know if same results and I can relay to the development team!
@Tostanica-fezanamu - They are both different AI Models and that is why they are different version numbers. They will produce different results as they are different AI models. The development team will continue to work on v2 as it has reports of being too cartoonish on some processed files, etc. This is why there was a added “send your image and feedback box” to make sure to get as much feedback as possible. There is also no “less flexibility in v2”, it was always the same behavior in v1 (where it renders the while image and allows change of selection after the process to avoid rerendering). The difference is a different AI model, that is much faster. In your Case, since you are on a M2 Pro, there is an issue with the blur, for which the development team is looking into!
@JakSpoon - The G9M2, even is same sensor as the GH7 will be detected by Photo AI as an unsupported model and can give out wither wrong colors or an error on export. To test! If it does, you can write to support@topazlabs.com and send an original RAW file from this camera and we can open a ticket with the development team to look into it’s support. In the meantime, instead of using the native RAW file, test converting that native RAW file to DNG and see if it works in Photo AI. If you have LrC, can do this on Import with the “Copy as DNG” option or use the Adobe DNG converter.
@Richard.J - it’s actively in the works - saw it with my own eyes. It’s a drastic change and still being developed but it will come! Thanks for your examples :slight_smile:
Hi all,
any idea, why Photo AI is failing after upgrading my graphic card to RTX 5070? Windows 10 updated, drivers from nVidia updated, Photo AI latest version… Problem is only in Sharpen module, denoise works fine. Does not matter if jpg, tif, raw, standalone or called from Lightroom. After export the picture looks exactly the same like in preview (whole object, not just the part like here in screenshot).
@miroslav.ondrisek - That will occur with Sharpen Standard, for these new NVIDIA RTX 5000 cards. The development team is aware and I added your contact info on their ticket and we can contact you once resolved. It’s also tracked here; [NDIVIA RTX 5000 series] - Sharpening "Standard" issues on this new NVIDIA card - #13 by alexandre.topazlabs - . For now, use Sharpen Strong, which you can force as the default model to be used in Edit > Preferences!
Thank you for the explanation and have a nice weekend.
Thank you for the clarification on this!
Then I will send an email soon to send a sample of the RAW file, even if it is a “famous” camera and well spread in the market (released in fact before the GH7, it seems strange to me that the support in the program has not arrived already)!
I sincerely hope that official support will be added soon, in the future!
For sure! I’ll keep an eye out for your email and open a ticket for its support :smiley_cat: Let us know as well if the DNG workaround works until it is! It would still be the RAW file, just the conversion needed till its supported.
My G9M2 files open in and export from Photo AI just fine, and have done for some time now.
