Today we have a patch release with AI powered upscaling for super focus when using focus boost, an huge speed improvement for super focus on Apple Silicon, and many bug fixes.
You can find the installer links and full changelog below.
AI upscaling in Super Focus
Using Focus Boost in Super Focus will downscale your image for processing and then upscale back to the original size. Previously, the upscale used non-AI methods.
Starting in 3.3.1, Focus Boost - Minor and Major settings now use AI upscaling models to process your image, creating a sharper result. We notice this especially when using Focus Boost - Major.
2x speed improvement for Super Focus on Apple Silicon
We know the importance of speed in running AI models, especially for Super Focus. Great news, we have doubled the processing speed for Super Focus on Apple Silicon so you can now preview and render in half the time.
Performance improvements are always happening from our team, we will have more to share soon!
v3.3.1
Released October 31st, 2024
Windows: Download
Mac: Download
Changelog
Refactor for controls, fixes many bugs with right panel, controls, and selection menu
Enable AI upscaling for super focus when using focus boost
2x speed improvement for super focus on Apple Silicon devices
Make holding alt invert mask brush
Enable applying settings to all and select all in filmstrip when in a selection mode
Automatic Lensfun Update
Updated enter and escape keys to work more consistently across the application
Fix apply current setting sometimes not active in filmstrip
Fix error running model with recover faces gen 2 when using PS File > Automate plugin
Fix application restarting after using super focus and closing the application
Disabled super focus on Macs with AMD Radeon graphics cards for now. We are working on a long-term fix here.
Known issues
High efficiency compression Nikon Z8 and Z9 files have color shift, will be fixed in a coming update
Crash when using Photo AI as a plugin from Lightroom Classic on some Windows 11 devices. We are working on a fix.
Canon R5 II and Nikon Z6 III RAW files are unsupported. We plan on supporting these in a coming Photo AI release. In the meantime, convert your file to DNG and they will work in Photo AI.
Lingyu Kong
Technical Product Manager
Topaz Photo AI
What is the current status of macs running Sequoia? I may be purchasing a new macbook pro and it will most surely have Big Redwood on it. I’d rather not have to downgrade to 3.2.
Just updated and started a CLI batch as a test and I get the following messages:
2024-10-31 23:49:52.7075160 [W:onnxruntime:, session_state.cc:1166 onnxruntime::VerifyEachNodeIsAssignedToAnEp] Some nodes were not assigned to the preferred execution providers which may or may not have an negative impact on performance. e.g. ORT explicitly assigns shape related ops to CPU to improve perf.
2024-10-31 23:49:52.7129157 [W:onnxruntime:, session_state.cc:1168 onnxruntime::VerifyEachNodeIsAssignedToAnEp] Rerunning with verbose output on a non-minimal build will show node assignments.
This didn’t occur with 3.3.0.
I’ve tried to set the AI processor to Auto, CPU and Nvidia GeForce RTX 3050 but nothing is changing. The pictures are generated and seem to look ok.
You absolutely need to render super focus just on the selected (masked) area. It will be so much faster. Right now it always computes super focus on the whole image even if the selected area is only 1% of the image
Hmmm, I just redid a photo I had previously done with 3.3.0. Super Focus 3.3.0 did a pretty good job, but 3.3.1 has problems. The AI upscale now creates incorrect features that ruin the image. Also, some non-masked portions are getting sharpened and some parts of the masked portion are not sharpened. Seems like a big step backwards.
M2 Pro 12/19 Macbook Pro 32gb.
Edit: I have been playing around some more and using the preview windows to see what happens as I change settings. For the Focus boost I reset it to None, let it render, then set it back to Major. This time the weird, incorrect AI features that were added previously when using Major were not there. I suppose with AI you can get different results each time you run it. Very unpredictable. Maybe if I do it again I will get yet another image. Still getting unmasked portion sharpened.
Standalone & Attempted Ps 2024 Plugin (got Error Msg via File > Automate, got Error Msg + Crashed Ps 2024 using Filter menu) - Snip of Error Msg below.
Image:
Blurry 2012 .jpg of model (badly lit) on tradeshow floor (oddly they were demo’ing how great their studio lights were, and she was totally blown out - but that’s not relevant here)
Goal: Determine what I can sharpen using SuperFocus in current PAI.
Standalone Version Steps:
Clicked SuperFocus - selected Subject only (not background) - Female model, PAI selected her accurately w/out me having to modify.
Settings used: SuperFocus: Strength = Medium, Focus Boost = Minor
Previews/Preview Processing Bhvr: Two preview boxes were used. For both, the Blue Progress bar tracked to the processing time from left to right (didn’t wing immediately to the right and stay there - better than previous rel.).
Clicked Render: Got ETA 9 minutes. Again, Blue Progress bar tracked to processing spd from left to right and included a countdown of the time remaining (which helps vs wondering if anything’s happening). Actual time to process was 7 minutes.
Decided to see if Face Recovery could sharpen the face more. Ran it after SuperFocus completed. When looking at Before/After Face Recovery - became obvious that SuperFocus had altered the model’s mouth, nose, chin area significantly.
Face Recovery restored her appearance to how it was in the Orig. image (just clearer). Struck me as the moral equivalent to how text got mangled and required a 2nd Preserve Text step to ensure no alterations to text. ** Perhaps there should be a Disclaimer box in the UI to verify human features haven’t been changed (if not desired). I didn’t use any “Creative” settings to alter facial features.
Exited PAI Standalone. It did not relaunch itself.
Tried accessing PAI in Ps as a Plugin. Didn’t work. Got Error Msgs (see also notes above and snips below) and a crash.
Snips - labeled in filenames: (track to the Sequence noted above)
v3.3.0 “select all” seems broken: only the first image has settings applied and is exported, all other images in batch are not exported because the settings were not applied).
Also noticed in 3.3.0: preview has two horizontal bands dividing the image into 3 where the image pinches in (shrinks in aspect) while the rest stretches (toggle processing on/off to see the bands “jump”). Appears happen in preview only, not the final export, so more cosmetic (and confusing).
This thing with AI and hands/fingers… it’s interesting how it can get so messed up.
Here is a snip of a hand before processing with Superfocus:
After processing Superfocus. Sharpen strength low and Focus Boost Major:
Here I’m glad I remembered someone saying - months ago in an earlier thread - that preserve text can fix not just only text, so I added that to the hand:
Still not perfect, but… the sources aren’t that good to begin with (I’m back to my HTC Desire photos from 2011-2012).
On another note… why is it that - after exporting a processed photo - the focusing process have to run again after having closed the export window and returned to the main window?
Seems awfully inconvenient having to wait once more for the Superfocus module to do it’s thing if all I want to do (for example) is try another setting on modules applied after Superfocus?
After using the Face Recovery mode (version 3.3.0), strange freckles appear on faces. In reality, a person may not have them, but after processing they appear. Please fix this bug.
