Thanks. After that, it was pretty quick, about 10-15 minutes in all. ![]()
Yeah, that’s true, but it’s still okay. ![]()
I think her wooden leg has come loose. I prefer the original picture. It reminds me of the effects in the 1982 film The Thing.
You’re right, 12 feet tall girls need love too!
Great idea Ken! There’s a number of improvements and fixes I’d like to see for the crop tool as well.
Hey Renar - are you using Remove on cropped or upscaled images by chance when encountering these quality issues?
Hi, Dakota. I’m not sure. It was an image that was given to me by someone else. It was not the best quality image too. Might this have played a role?
Crop still doesn’t work!
Additionally, in countries where the decimal separator is a comma and not a dot, no value can be entered in the Scale field. You can only enter a comma, but then it does not calculate the width and height. And you can’t enter a dot.
Use a non-standard scale, for example enter width 3000.
Use face recovery.
Is there a newer version than 2.3.2 where this worked properly?
the old version is unusable, due to tiling artifacts
then let them sign up to be beta testers.
Has any noticed that you basically can’t batch upscale in version?
After you “SLECT ALL” it will only process those which you have “went on”, that have been autopiloted, otherwise it will just skip everything else. So if you’re trying to upscale a large amount of images, you’re expected to manually enter each image first and have them autopilot. ???
Pre-V3 you used to be able to just drag everything into the program, click Upscale all, and it will do the Autopilot automatically during the export process.
Based on this review posted by @Tostanica-fezanamu above, the grid is still present, hence still useless (at least for me).
I am also seeing preserve text not working where it worked before. I am in Win10x64.
Is the next TPAI release planned for today?
At this time the releases are every other Thursday, The next one should be on May 23rd.
Yeah, I have the same problem. A swede living in Spain that can’t upscale with the separator I’m using just about every day of the week.
The problem has been mentioned on several occasions, bit there doesn’t seem to be any interest in fixing it.
Funny thing is that if you Google the subject you’ll find there’s a not an unimportant amount of countries that use the comma.
But hey… I guess all is OK as long as the ones across the pond from us don’t have any problems, right? ![]()
More countries use the comma than the dot, as a decimal separator! But population-wise, due to China and India, it’s the other way round.
The potential problem of decimal comma countries using a dot as the thousands separator is simply avoided by not allowing either of them as thousands separators. Then, Topaz can allow either a comma or dot to be the decimal separator. Simples. You’d have thought.
Even better, allow the user to choose which method to use in the Topaz product they bought.
Yea i noticed that too and imo the Autopilot should always do the full job on any picture with every feature of Topaz Photo AI.
I personally do not want to fiddle with sliders and stuff and having to decide whats the best settings for every individual picture. I’m not a pro photo editor by any means and have no clue about whats needed in this or that picture or where the pictures have areas to improve and how much to apply each function like sharpen, denoise ect. if you get what i mean. Just having the Autopilot deciding the AI model is not much of a help for me ![]()
I just want the Autopilot AI to analyse the imported pictures individually one by one and decide and apply every Topaz Photo AI feature and it’s strenght thats needed to improve my pictures in best possible way on it’s own. Setting the output resolution, format is all i want on my own ^^
Basically i look for the “One Click Solution“ option from AI programs. Doing everything manually is great for the expert users that know what they need to set and how the best endresult should look like.
Is there a older Topaz Photo AI build in which the Autopilot worked best and did all things you would expect from it ? Would be very happy to get some recommendations what Photo AI build to pick and go back to for the moment and fully AI Autopilot assisted mode ^^ Thanks ![]()
