The raised hand of the girl in red is slightly odd, though.
âblack girl playing the blues, roadhouse, crossroads, low light, shallow depth of field, smoky roomâ
Seed : 848552 | Steps : 25 | Img Width : 832 | Img Height : 512 | Model : photon_v1 | Mode : txt2img | Selected Style : dark fantasy
thanks. By the way, your generation has 6 fingers on one hand
Makes for good pickinâ!
Do you mean the original or the edit? I see it on the original.
Note that Leonado AI simply uses the free Stable Difusion templates. Added to this a few models modified for Leonado AI
I also have SD installed locally via Terminal FWIW.
FWIW? What is it?
For what itâs worthâŠ
I was looking at a smaller version and didnât see this. I corrected it, thanks
Just for testing purposes, I first tested your original image to make a light variant. And then improve the hands and eyes
Youâre welcome
Here are some of the primary models that Leonardo uses.
dreamshaper v7 is old. Now, here is âdreamshaperXL_sfwTurboDpmppSDEâ for Stable Diffusion. And you only need 5 steps.
If I simply use your prompt with my best model, i.e. âdreamshaperXL_sfwTurboDpmppSDEâ with your seed, I get this
Good stuff!
See, this is what happens when there is no weekly PAI release to test
We need to teach AI that guitar strings are always straight!
Nice work though.
Yeah, some things are still a problem. Thatâs why Loras also exist. Theyâre models for very specific things. And thanks
