Do you intend to fix the PPI problem with 2.3.0 as you just did with Giga version 7.0.1 patch (working ok)?
Same issue/bug crashes as Svetlina & Harald above. PAI 2.3.0 crashes consistently/repeatably when using Remove Tool w/out 1st using scaling. I’m trying with low res stock images just so I’ll have test pix that can be scaled up for the test purposes.
It crashes very shortly after I click “Remove” (after placing the Remove overlay where desired on the image) and it starts processing for a few seconds. Like the others above, I didn’t experience the crash if I created an upscale amt 1st.
Win 11 PC. Using as Ps 2024 plugin (via File > Automate menu). Processor = AMD RX6800 XT.
Just as a caution that under Win 11 with GTX3060 using as a standalone I don’t have any issues so there may be other factors such as using as a plugin via automate from PS etc.
